The '77 to '81 cases??
Discussion in 'Vintage/Left Kickers' started by Bigbill, Oct 7, 2016.
  1. Bigbill Husqvarna
    '83 250wr
    0 right now
    Can we install a 390 crank in a 250 case? I'm thinking the center case gaskets are the same? It's another avenue to save a battered case and keep it alive. Just a thought.
    The '77 / '81 250, 360, 390, 420 would interchange. I'm not positive but with different gasket sets that are offered maybe The intake size with the reed box may vary. More research is needed. Does anyone have knowledge in swapping cases?
  2. Kartwheel68 Husqvarna
    Newnan, Georgia
    I believe they do up to the '80 390 which has wider stud spacing. I think even the 76 175 has the same outside diameter crankwheels, only the big end pin location for stroke is different.
  3. Bigbill Husqvarna
    '83 250wr
    0 right now
    The crank I purchased has the 390 crankwheels but they call it a 250 crank.
  4. grouty Auto Lover ...
    South West UK
    78 390WR, 78 390 AMX, 500 Humph
    works 73 CCM 520, another 73 CCM520
    Have you measured the stroke Bill ??
  5. Bigbill Husqvarna
    '83 250wr
    0 right now
    Not yet I need too. I have a 420 cylinder and maybe an extra bottom end.
