The Dreaded Slave Cylinder O Ring Fail
Discussion in '4 Stroke' started by Huskynoobee, May 1, 2020.
  1. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    It finally happened to me. While not as much of a problem on the post big block Italians (449/511) these do wear out with engine heat over time. Mine gave up finally on a ride with none other than Ty Davis. I won't go into details, but suffice it to say that I got myself into a spot where the clutch lever just went dead. Usually (and for some reason only when I ride with Ty) the fluid will get super hot and once cooled the lever comes back. Not this time though. Luckily I know this guy who stocks the proper Viton O Rings to get me back in action. As you can see it's pretty done. IMG_20200501_153707.jpg
    moreccsthanlbs and Dirtdame like this.
