125-200cc Thickness of the stock base gasket - wr125 09
Discussion in '2 Stroke' started by OmerG, Jul 8, 2014.
  1. OmerG Husqvarna
    WR125
    Hi freinds, this forum is great!
    Can someone please tell me what is the thickness of the stock base (cylinder) gasket for wr125 '09 (the one that came originally from the factory..)??
    Thanks!!
  2. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    0.8mm I think(thickest)
  3. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    I think it was .5mm - from memory
    I ran a .3mm one recently
    R_Little likes this.
  4. typeone Husqvarna
    central MA
    07 TC270 + 09 WR165
    08 X4 146 + 13 250RR
    i also think stock was 0.5mm. i ran the 0.3mm with the 144 kit, ran great. bumped up to the 0.8mm with the 165 kit.
  5. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    maybe I was thinking of the 300s? 0.8mm with 165 though is correct
  6. OmerG Husqvarna
    WR125
    How can I be sure? It doesn't mentioned anywhere in the workshop manuals I have...
  7. rockdancer Husqvarna
    It's .5 mm
  8. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    he'd know^
  9. budpat105 Husqvarna
    2004 TE 250, 2008 wr250
    Honda CRF230f, Yamaha TTR230, Suzuki
    ok - take us to school on this, why the different thickness offered and how do you determine which gasket you need. Thanks
  10. rockdancer Husqvarna
    On the 125 - If you use a .3mm gasket you will lower the cylinder and head .2mm which increases the compression ratio
    It will reduce the squish band thickness to approx. 1mm - basically the gap between the piston and head - also changes the port timing slightly so its better to get the head machined instead
    but a cheap way of generally pepping the bike up a bit . You can do a solder test to get a squish band reading .
    You need to watch out for detonation though
    Have a look at thread index - under head mods
  11. OmerG Husqvarna
    WR125
    Someone knows if the Mitaka top end gasket kit comes with few base gaskets in different thickness? I can't get info about it.
  12. Caferacerman Husqvarna
    Any suggestions on reputable machine shop guys that can mill the head?
  13. slo rider Husqvarna
    WA
    2009 WB165
    2007 YZ250
    jmetteer likes this.
  14. wallybean Mini-Sponsor
    Montana
