Those friggin snap fit hose clamps...
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by Boogie, Apr 2, 2014.
  1. Boogie Husqvarna
    Australia
    Red head
    These clamps annoy me. I don't have the install tool and always struggle to get em on and off...
    What do you guys do to remove and replace?
    Is the correct tool the only answer?
    I'll usually replace with a "normal" screw type hose clamp if I have one lying around, but sometimes have to reuse these friggin snap things.
    Here's a pic of the little devil clamps and tool.
  2. Freaky Husqvarna
    Kidderminster Worcestershire UK
    2010 TE250 x-lite Race ECU/Injector
    I replace with Jubilee clips, easier to remove/replace and I know how tight they are.
    OlderHuskyRider, duggoey and Boogie like this.
  3. Boogie Husqvarna
    Australia
    Red head
    They're the "normal" clamps I was referring to.
  4. HUSKYnXJnWI Husqvarna
    Central Wisconsin, USA
    09TE450
    I just "gently ruin" them with a pair of snips/wire cutters/pliers/screw driver to get them off. Replace with normal snail clamps (as above) or fuel line clamps for smaller applications.
  5. ray_ray Mini-Sponsor
    The Philippines
    Never knew you needed a tool for those OEM clamps ... I guess that is why once I removed them, they were tossed and replaced with a normal type ...
  6. AndrewS Husqvarna
    Niagara Region, Ontario, Canada
    2015 FE350s 2013 TE310R
    2009 TE250 (sold)
    I replaced mine with fuel injection hose clamps.
  7. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
  8. steadydirt Husqvarna
    Ontario
    2007 2002 wr 250 1994 wxe 250
    OEM with the correct tool are faster
  9. duggoey Husqvarna
    NSW, Australia
    2010 TE 310
    KTM 690, Yamaha WR200, FGS650(800cc)
    The general consensus is that nobody likes the snap fit clamps. I do as you - the tool is a pair of snips, remove that thing and replace it with a threaded clamp
  10. Micfasto Husqvarna
    2012 TXC 310
    XR400, Vstrom
    End nippers or side cutters to remove and instatll the OEM clamps. They are reusable.
  11. Xcuvator Husqvarna
    Scholls Oregon
    yes
    Yeah, I like to replace them with a worm gear type but if there isn't one handy I have reused the OEM with one pair of pliers to compress and another to snap it together many times.
