  • 2 Stroke Husqvarna Motorcycles Made In Austria - About 2014 & Newer
TE/TC thottle cable routing
Bryguy215
I'm buy the motion pro cable and throttle tube. Can anybody tell me if I should stick with the stock length and routing or should I get the longer cable and route it a different way?
If you go over to KTM Talk, you'll see that most people like a longer MP cable and routed behind the number plate/headlight over to the left. I've run the stock routing on my Husaberg TE250 and Husky TE125, with no problem. I don't run a steering damper though. My Italian Huskys had the same routing, without issue.
I run OEM throttle and cable, had the metal cable holder from GPR to keep it off the stabilizer----it broke after a few rides. I simply made one of the hose and zip ty stand offs for my cable and have never looked back----many hours and an H&H with set up with no issues. So there is another config option for retaining your cable where ever you route it
I don't have a damper yet but I am pretty sure I am going to get a scotts with the rubber submount. That won't be for awhile tho. My throttle stuck twice but had never done it since. At this point I want to change the cable and tube to help bring back my confidence in the bike.
