125-200cc throttle cable routing/lectron elbow
Discussion in '2 Stroke' started by shawbagga, Mar 19, 2015.
  1. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    does anyone else have a heavier than normal throttle pull with the lectron/MP cable set up? my 300 with same set up is light as anything but notice the 165 is twice as heavy maybe more! snaps back fine, cable routing is ok & no kinks/sharp bends/pinching cable near new & clean. so am thinking the only thing it could be(which is different to the 300 too) is the little right angle elbow on the top of the carb? be due for a top end soon so will double check routing & flush/clean cable to be sure its not that. thoughts?
  2. Yellowfin Husqvarna
    Ocean City, NJ
    '13 WR144
    kdx220 (sold)
    Mine seems smooth and normal
  3. Motosportz CH Sponsor
    There are three slide springs for the Lectrons. Soft, medium and firm. Try the soft one. I have not noticed harder pull on the many I have installed and used. I did switch to the medium from the stiff one on a YZF450.
  4. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    Got a soft one and dont really think its up to the job as a few times when used on a mates bike it never dropped back to idle properly ! Yes it may of been his cable routing but its been fine since fitting the medium spring, Does give a real light pull though.
    Motosportz likes this.
  5. Motosportz CH Sponsor
    Yep, that's the trade off to running a soft spring.
  6. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    i run the heavy spring, and it feels similar to a older roundslide carb. thats the feel i prefer. mine was very easy to turn with the medium spring, too easy in my opinion. i use sea foam deep creep for cable lube as i find it excellent! i do have a 90 degree cable so i dont think the angle is your problem.
    i also think its kinda important to lube the cable on a lectron machine every so many rides, as a couple drops seeping from the cable onto the slide area is good for it. keeping that spring lubed there helps too. i love the lectron but hate how their slide feels with that little spring. im used to the old vm mikunis that feel awesome! of course you dont want to flush the carb with cable oil but a few drops seeping down there is very helpful to tame the "grit" feel cause by that spring and rough slide.
    NCSteve likes this.
  7. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    what spring do you send them out with Kelly? is there a way to tell from looking at spring(notches/number etc)? by chance were the original lectrons(unshortened) shipped with medium spring & newer version with heavy spring or vice versa? i did send my 300 lectron back to Kevin for the shortening treatment so he may very well have put the medium spring in then. medium sounds the go. hadnt really noticed that much until rode 300 coupla weeks ago with same lectron but much lighter pull.
  8. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    i gave both cables a good flush through with wd40 prior to installation & put some 2T oil on slide/spring/rod area
  9. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    so installed new MP cable(direct thread into top of carb type-no 90 degree bend/elbow) today on 125. flushed it with wd40 first. wow that's how it should be! so light now compared to how it was. im not saying it was for sure the elbow causing heavy pull as there was a couple of indentations on old cable housing that could have been affecting things too but either way im stoked. I actually prefer the direct thread in type with rubber boot, seem more waterproof imho. makes bike feel so much lighter too. problem now is that my 300s throttle pull(which I thought was pretty light) feels so heavy! think she just needs a lube is all
  10. justintendo klotz super techniplate junkie
    amazing what a little lube can do! ;)
    shawbagga likes this.
  11. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    ^yup. flushed out the 300s throttle cable too the other day. again wow super light now. amazing how much difference light controls make to the feel of a bike!
  12. Motosportz CH Sponsor
    These work great for lubing cables but you have to remove one end of the cable to do it right...
    NCSteve likes this.
  13. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    yeh theyre cheap & im sure very effective but I do it the lazy way(with clutch cable at least) by just laying bike over & spraying it down the cable housing
  14. flyingbob Administrator
    USA
    01&02WR360_02WR250_02CR250_12WB165
    01 VOR400_07 TM450_22 GG250_07 Tuono
    Ahh, just spit on it
    NCSteve likes this.
  15. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    Having that thing motivates me to lube my cable more often. Just did both and clutch improved noticeably even though I hadn't noticed it was prob.
    I use Blaster silicone for oring chains and cables, works great. Don't let that drip into my carb though :rolleyes: A drop of premix oil for me too.
    Also, I think it was Kevin who said to use a Scotch Brite pad to smooth any rough spots.
    :cheers:
