250-500cc Throttle Cable Routing...
Discussion in '2 Stroke' started by d7b, Jun 5, 2013.
  1. d7b Husqvarna
    Sydney
    2008 WR250
    Sach Madass 125cc +142 big bore kit
    Thought I had a sticky throttle cable for a year now. made some wild rides on ridges etc in the middle of nowhere if you know what I mean :S
    Anyway, I had cleaned the cable, snapped back fine, cut rubber off grips and made sure it wasn't the bark busters interfering ....problem still occurred.
    After a mate was tuning my carby last night and I was about to wheel it out, i full locked right and the throttle cable snagged and rev'ed the bike up hard... This is what had been happening. The bloody universal 'safety' pad could/will make the throttle cable snag.
    Is this the normal routing?! Seems in the workshop manual that it is... My solution will be to get a fat cable tie and pull the throttle and clutch cable towards the centre of the frame (through the hole in the frame) to keep them either side of the tank breather and out of the way. Seems fine when moving left or right. What do you think, gents?
  2. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    my cable is nowhere near that length
    is it oem (stock)?
    your clutch cable takes a wierd route too
  3. street2dirt Husqvarna
    World's Most Famous Beach
    12 TXC310, WR300, 85 125WR, 82 175XC
    BMW G650X
    I thought the same thing, shouldn't the cables be in front of the bars?
  4. d7b Husqvarna
    Sydney
    2008 WR250
    well, I concur on both counts here ! But my workshop manual shows the same routing.
    Both OEM according to ordered part numbers from my local distro...
  5. 2premo Husqvarna
    Northern NV
    my throttle cable has that routing but it is WAY shorter, maybe try it in front behind the number plate
    and my clutch goes behind the number plate
    d7b likes this.
  6. Glenn haynes Husqvarna
    western pa
    2012 wr300
    13 yz250f 08yz85 11ktm 65 09 ktm65
    that routing looks just like my 300 from the factory,don't know if yours should be the same or not.
    d7b likes this.
  7. d7b Husqvarna
    Sydney
    2008 WR250
    pulled them together with some cable ties and works fine. Thanks for all your help.
    However, if you don't hear from me again, the cable tie snapped and so did my spine ;-) Probably a better way to route them behind, but will do so when i inevitably replace my bars soon, but this weekend....we ride
  8. 2premo Husqvarna
    Northern NV
    excellent idea, so am I
    d7b likes this.
  9. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    This is how the cables on my WR300 were routed from the factory. Since I don't run a bar pad on this bike, I have not had any problems.
    d7b likes this.
  10. street2dirt Husqvarna
    BMW G650X
    To me:confused: that just doesn't look right. My bike has the clutch cable in front of the bars then between the steering head & the right fork tube. The throttle is between the steering head & the left fork tube. I may take a pic when I get home. I guess that depends on who puts the bars on at each dealer when new.
  11. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    mine the same as dirtdames & im in AUS!
  12. giantjoe Husqvarna
    Canadia
    2010 WR300
    I had the same problem after full right lock. I fed the cable through the riser box behind the bars, never had a problem since.
    d7b likes this.
  13. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    aslong as it dosent hook up or snag its fine, i run mine infront tof the bars and under the barclamp crossing over under the handlebar, is that makes sense.
    d7b likes this.
  14. d7b Husqvarna
    Sydney
    2008 WR250
    I think I just inoculated! Some mad scenery ! what a ride that would be
  15. d7b Husqvarna
    Sydney
    2008 WR250
    It's fine by the way. Thanks for the feedback. No spinals. Just husky madness. God damn I hope KTM dont run these guys into the ground.
