All 2st throttle fail-'09 300WR
Discussion in '2 Stroke' started by steadydirt, Mar 13, 2016.
  1. steadydirt Husqvarna
    Ontario
    2007 2002 wr 250 1994 wxe 250
    Caught an odd one this AM on the Mikuni. This carb spring[inside the slide] is stiffer on the '09 than in earlier 2T mikuni carbs. The throttle pull is a wee bit heavier. The surprise was when I inspected the steel cable housing that screws into the carb cap. The cable had cut right through the tube and was exposed for 10-12 mm. Not that many hours on the unit. Nasty. A hole for air/dirt!
    New to me.
  2. Crocus Paper Husqvarna
    UK
    WR250
    Scorpa 300 Aprilia Dorsoduro 750
    Yep, same here. I had this on my 11 WR250. Defo one to watch.
  3. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Replace with lectron real simple cheap mod, paid for itself in gas within two years!
  4. boomhauwer Husqvarna
    Belgium
    WR300, Nuda 900 R
    Triumph Street Triple
    had that problem as well..replaced the whole carb with PWK :D
  5. buzuki Husqvarna
    sydney, australia
    WR300 '09
    KDX200,KX125,CR250,50cc quad,
    found the same issue on mine recently, only has around 1500km tops. Was cleaning the carb out and relaised there was so much dirt on top of the slide, had me stuffed where it came from and then...
    steadydirt likes this.
  6. steadydirt Husqvarna
    Ontario
    think it is because the throttle return spring is stiffer- more tension on the internal steel cable- I changed my spring and have a lighter throttle pull- could feel it on the first ride with this new to me 300- the throttle was too heavy- best dirt bike i have ever ridden btw!
    Dirtdame likes this.
  7. Claybilly17 Husqvarna
    Ohio
    2000 WR250
    2009 KTM 450 SXF
    What Spring did you change it to?
  8. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Ball point pen one?
    Claybilly17 likes this.
  9. Claybilly17 Husqvarna
    Ohio
    2000 WR250
    2009 KTM 450 SXF
    Ahhh Juicy you always seem to make my day :D I love your smart a$$ sense of humor! :love:
  10. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    Don't encourage him Clay!;)
  11. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    If i only make you happy my lifes worth living. ;)
    On a side note anyone felt the slide outta a berg fe400 03? Its made of brass an weights a tonne, dont think it needs a return spring unless it ends upside down.
  12. steadydirt Husqvarna
    Ontario
    Pardon the delay- just found this- I used a throttle spring out of an older TMX I had spare- same number of coils but slightly finer spring wire- feels a lot better to me- no arm pump
