Throttle issues
Discussion in 'EFI/carb' started by Mr_X, Jun 25, 2012.
  1. Mr_X Husqvarna
    Singapore
    Hi,
    I'm riding an SMR510 2009, after installing the race Arrow full system with racing C.D.I, the bike would die if i snap the throttle too quickly. What should i do? I know how to ride but Im a noob at E.F.I issues..:(
  2. HUSKYnXJnWI Husqvarna
    Central Wisconsin, USA
    09TE450
    Did you set the TPS with I/beat after you installed the new CDI? If not that is most likely the issue and what you need to do- since your CDI needs to be matched to what the Closed Throttle voltage is coming from the TPS.
