Throttle Tube Question
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by PineapplePicker, Mar 10, 2014.
  1. PineapplePicker Husqvarna
    Henderson, NV
    2013 WR125
    2004 Harley-Davidson FXSTI
    Bike: 2013 WR125 w/ OEM Throttle assembly.
    Is it necessary to disconnect the cable from the throttle assy to remove the throttle tube from handlebar for cleaning?
    After a spending a couple of hours learning to ride sand washes, and being dumped, my throttle tube/grip now sounds like there's a bunch of sand in there I need to clean out.
  2. rancher1 Husqvarna
    WA
    That would be the easiest way to go, but I suppose you could unbolt the handle bars and just loosen the throttle assembly and slide it off whole.
    PineapplePicker likes this.
  3. PineapplePicker Husqvarna
    Henderson, NV
    2013 WR125
    Thanks rancher1. Appreciate your response.
