Have my smart carb running great except for wide open throttle. Am going to install a power jet and only want it to add fuel to the wide open portion of the carberator. Any suggestions on placement of the powerjet,top,side ectra, and I see lectron users are shortening the tube length into the throat. What does that do to operation? Also do you want it as close to possible to the slide.?? I only want to drill one hole so please help.THANK YoU
Makes the PJ come on later / have to twist the throttle further to get to it. I kinda started that because I felt the PJ was stepping on the mid range to much for my liking and this moved it up the range.
