Tight gas cap
Blaster11
Are all the gas caps on the TE449/511 really tight to get on and off? Do they loosen up or can you lube it with Vaseline or something? Or is their a replacement cap which cures this? I thought I had it tight the other day but when I stopped after some trail riding I noticed that it was wet from the gas coming out so I tightened it down but when I went to fill it was really tight.
They all seem that way from stock. I complained until the dealer bought me an aluminum one. That totally cured the problem. (Thanks Honz)
Are the aluminum ones factory or aftermarket? If factory which bike is it from and if aftermarket who sells them? Thanks!
If anything they get worse with time, but Ive managed to make mine work for almost 3 years....must be the perfect humidity level in Oregon or something.....
What fuel are people using where the cap is bending?
I know that my old Hypermotard had a recall on the tank as the material didn't like E10 mixed fuel. Its expanded.
We get ethanol and a special ” summer blend” here in CA. Just a scam to create short term supply issues when they switch back and forth so they can soak ya for a couple of weeks.
i like the aluminum gas cap but $70 is a little high dont u think!?
Not sure what it takes to make one of those, could be a lot of scrap metal after machining. I know the price of AL is quite high last I checked.
In any event, personally I think of 'value' when it comes to things like that. "functional bang for the buck" type of thought process.
Though I suppose I should not comment because I do not have a 449/511 bike....
