I want to take off the DOT tires. These are the tire sizes. 120-90-18 rear 90-90-21 front What size would I change them to? Not many choices for these sizes.
Are you asking what tires will fit your bike? I thought almost any 21" front and 18" rear would fit ok. Maybe someone else has more input.
Tires I wanted to keep the same diameter for the speedo. The tires that I'm looking at the rear would go from the stock 120-90-18 to a 110-100-18. I was told today that the tires on the bike will will have the same aspect ratio as the ones I'm getting.
If you look in the Michelin brochure, it has the 120/90-18 equivalent listed as 100/100-18. 90/90-21 is 80/100-21.
Bridgestone I ordered a set of Bridgestone M-403 & M-404's. I'll let you guys know what I think once I get them mounted. Thanks Jeff
It seeems to vary slightly from brand to brand. I replaced a 120/90-18 on my TE250 with a 110/100 Dunlop and the fit was OK. When I tried a Michelin in a 110 it seemed a little large for the bike.
