You need to tell us where you intend to ride in order to get any kind of intelligent answer, or spend some more time reading!
I did have a little problem with a slightly out of round rim in the Terra, something not experienced on any new motorcycle that I've ever owned, so it's something that folks might check.
Travis, I used the stock hubs. You might save a little going to Woody's version of the RAD hubs, but not a lot. The Excels are strong and beefy, so not much there either. You'd have to go more exotic to do a lot of good on unsprung weight, IMO. This is probably not the machine to try and make into a flyweight. If someone comes up with a single exhaust that would definitely cut some pounds, as would a Shorai or equal battery. This is my road/light adventure bike, and as such, the weight is OK. In fact, it's good! If I want to get rambunctious I go to my other trail bikes.Did you reuse the hubs or did you get new ones? Weight difference over stock? I rode a TR over the weekend and really like how smooth the motor is compared to my TE630; I mainly use the bike to commute but I'm not sure I can accept the 60 lb weight gain for offroading. Trying to think how much weight loss is practical on the TR.
I have not addressed it yet Tinken, but I agree. If I can't get it right, I will get ahold of them. The first problem I had that you mention was on the front tire. That issue went away in about 10 miles. I believe it was from the little rubber strings left on the tire from the injection mold process. Once those wore off, everything was fine..plus it was very cold that day. I believe the issue on the rear tire is just a mounting issue. Where the weight you see is, is where the tire stem is suppose to be. I need to remove it and relocate it. I will post when it is resolved.Hmmm, I have never seen a Rally Raid tire that far out of balance before. I remember when you first installed it that you mentioned something about it being out of balance, but that it self balanced after a while. That's a really reliable tire, especially for the weight of the Terra. If you can't get it balanced, I'd give Dunlop a call, that's their premier tire.
