All 2st TMX Issues
Discussion in '2 Stroke' started by dartyppyt, Mar 9, 2009.
  1. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Started my bike yesterday from it's long winter sleep and gas was flowing from hoses.
    Took carb off and discovered float/needle were not seating. It had to come from factory like that. Owners bible doesn't state float level height. I made the floats level anyway. Does anyone know the float level height?
    Also. went to drop my needle down one clip. Took a socket to back out the clip hold down nut/throttle cable groove. When you go to back off nut, it squishes the cable slot and the socket spins. Can't get the nut out?
    Anyone have a similar issue?
    Thanx!
  2. dubbs Husqvarna
    Ontario
    I did the same thing the first time I took the needle out. Crushed the cable guide hole a little. I just bent it back and filed it our a bit and it worked good as new.
    As for having the socket spin on the nut... I'll have to take a look at mine and see what can be done.
