250-500cc TMX38 vs. TMXX38 on WR250
Discussion in '2 Stroke' started by Bench Racer 117, May 25, 2011.
  1. Bench Racer 117 Husqvarna
    Oregon
    2007 WR250
    Has anyone switched to TMXX38 Mikuni carb? My friend has one sitting off his WR125 and was wondering if I wanted to try it out.
    First, what's the difference?
    Second, what gains/losses would I get out of the switch?
    Third, what jet sizes should be used? The current settings I have now?
  2. NWRider Husqvarna
    It would be too short. Maybe it would work with a reed spacer
  3. pvduke Husqvarna
    ... on the gas...
    tripple-hondo hoosk...
    IF...it fit. youd gain bottom and loose top and 125 jetting would prolly be way too fat in most cases. generally speaking smaller carbs gernate more velocity @ a given openeing due to a smaller venturi. it's trying to suck the same air through a smaller hole. this can benefit some engines low speed opperation to a degree etc etc....
  4. Bench Racer 117 Husqvarna
    Oregon
    2007 WR250
    Thanks for the help. I didn't know it was shorter. Case closed.
