125-200cc Too low squish?!
Discussion in '2 Stroke' started by prjctmrx, Jun 29, 2019.
  1. prjctmrx Husqvarna
    Czech republic
    SM 125 07
    So, i've reduced the squish on my sm 125 '07 to exactly 1mm and it ran good since now. My spark plug failed, it never happened again so i blame it on the squish? The end of the spark plug burned off. Is the squish too low or has anyone experienced the same problem? Are you using different spark plugs?
    Btw it has tmx38 with
    400main
    35pilot
    4.slide
    Needle on 3rd notch
  2. lankydoug Husqvarna
    MO
    WR
    TM 300en
    A 400 main is pretty lean for a 125 are you sure that the plug didn't fail because of a lean main jet? My 125 needed a 450 main. Can you post a picture of the spark plug?
  3. prjctmrx Husqvarna
    Czech republic
    SM 125 07
    Im pretty sure its good right now, theres like 35 degrees celsius, tries 410 and the spark plug was really black. I will post a picture of it when i find the old one.
  4. Zomby woof Husqvarna
    Ontario, Canada
    2011 CR 150
    1 mm squish is fine. The problem is elsewhere
  5. wallybean Mini-Sponsor
    Montana
    400 in the older TMX is like running a 480 in the new TMXX.
  6. prjctmrx Husqvarna
    Czech republic
    SM 125 07
    Checked the new spark plug i put in, theres something horribly wrong...
  7. prjctmrx Husqvarna
    Czech republic
    SM 125 07
    It is the old version
    lankydoug likes this.
  8. jeanjean Husqvarna
    Netherland
    WR 125
    IT175H
    Ignition point?
    jeanjean
  9. Flyin Husqvarna
    Northern NJ
    WR 300
    What plug are you using?
