Do you mean to say that you have no tools at all?
Well The biggest tools would be torx bits need long and short ones. Also will probably not have a socket big enough to fit the oil plug on the bottom.
When buying sockets look around for a 6 point set .....they are much more reassuring to use, don't tend to slip, fit better, last longer and don't cost much more.
Rather than a 12 point socket set. Look in a trades tools shops.
With Torque specs, a Newton meter is not the same as Foot pounds.
