250-500cc Top end rebuild now backfires!!??
Discussion in '2 Stroke' started by DargoRider, Jun 6, 2015.
  1. DargoRider Husqvarna
    wr250 2006
    TE450 05
    Hi guys,
    Just completed a top end rebuild (shattered piston) on my 07wr250... Case split and cleaned by the shop, and re assembled yesterday... Problem is it started 4th kick, over revved due to throttle cable being stuck... Now all I can get is backfires, kick backs and no action.... I have pulled the carby, cleaned it, inspected reeds which are fine and checked plugs which are all good.... Everything moves as it should...
    I am suspecting a woodruff key detonating.. Timing seems out of whack...
    . Has anyone had similar problems?
    I don't have a puller yet... But will source on ASAP...
    Any thoughts?
    Cheers
    Steve....
  2. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    timing slipping is a decent guess, your mag only relies on the woodruff key for alignment
    did you assemble it yourself?
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    if you assembled the top end...is the piston backwards?
    how long did the bike rev up with the throttle stuck?
    when you say it backfires, is it firing thru the exhaust or back thru the intake?
  4. DargoRider Husqvarna
    wr250 2006
    TE450 05
    Thanks guys,
    Finally worked it out - detonated woodruff key! Assembled by shop and missing the washer behind the nut on the crank, so wasn't tight enough.... A quick rev must have had enough torsion to shear the woodruff when the flywheel was loose.... Probably a $1 fix, just need to find a new key now.....
    Thanks heaps guys... Will let you know how it goes...
    Nice amount of compression now!
  5. 2premo Husqvarna
    Northern NV
    something to remember the key is for alignment
    before you install the key and the mag use lapping compound and lap the mag to the crank stub, wipe off the lapping compound and install the key and torque the nut
    Petar likes this.
  6. DargoRider Husqvarna
    wr250 2006
    TE450 05
    Thanks 2 premo, will do.
    I'll have to wait to get the key, at least it's sorted....
  7. DargoRider Husqvarna
    wr250 2006
    TE450 05
    I've found the key online, but does anyone have the specs / dimensions for it?
  8. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    If your desperate just find a large washer or a bit of steel and make one that fits - 15 minutes with a hacksaw and a file and your good to go, dosnt even need to be pefect as its only as stated above for alignment and you have the two halves to copy :thumbsup:
    Petar likes this.
  9. DargoRider Husqvarna
    wr250 2006
    TE450 05
    Cheers johnnyboy... A bit of shed time doesn't go astray!
    johnnyboy likes this.
  10. gazmcfaza Husqvarna
    uk
    husky wre 125
    , yamaha xt 125
    in case this ever happens to me, what is a wood ruff key? Is it the thing on the lh side of the engine where the magneto is?
  11. justintendo klotz super techniplate junkie
    yes, shaped like half a circle. used to index the flywheel
  12. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Come guys your on the second most powerful tool in the world and you cant be arsed to log onto another page and search for the woodruf key?
    The most powerful tool is you! just incase you were wondering.
    pablopaints and NCSteve like this.
  13. justintendo klotz super techniplate junkie
    hahaha, but its soooo hard to look things up on google:lol:
    juicypips likes this.
  14. Hammerz Husqvarna
    Measure the width of the slot in the crankshaft go down to your local engineering supplies store and tell them you need a woodruff key that size don't file a washer this isn't the 1970s
