Torque settings
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by glangston, Jan 13, 2009.
  1. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
    A guy busted the fastener on one of the oil filter screens torquing to factory 18 ft . lbs.
    What likely happened? No o-ring, dirty, too big (innaccurate) a wrench?
  2. Coffee CH Owner
    Dunno, seems some of the hardware is not the quality it once was, 07/08 or was it an 06 and earlier?
    I usually do not use a torque wrench and go be 'feel'.
  3. RumRunner Husqvarna
    Yucaipa, CA (SoCal)
    2007 TE 450
    I broke one of the screws on the oil filter screen also. I was using a properly calibrated torque wrench set @ 25 Nm (about 18 ft/lb). The o-ring was there and everything was clean. I think some of the fasteners are not the "top of the line" well at least on my '07. That has been my only complaint w/the bike! I have since replaced those screws w/Stainless steel hex heads and it has held up great.
  4. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    wow is that what the book says?? from experience that is way hi for those types,,,,we usually go @ 6 lbs/ft at most on case/cover screws.
