Anyone know the specs for tightening the bolts for the springs on the clutch pressure plate?? Thanks in advance!
Clutch disassembly - Using an 8 mm wrench, unscrew the six screws (6) securing the clutch springs. Remove washer, springs, pressure plate (7), washer, axial bearing (8) and clutch plate pack (10). Collect actuator plate (9) and rod (5) from gearbox input shaft. - Lubricate the new plates with engine oil and install them (always start with a friction plate). Refit clutch actuator plate, bearing and pressure plate. Tighten the spring screws gradually in a cross pattern (8 Nm - 0.8 Kgm - 5.8 ft/ lb). When refitting the clutch cover (8 Nm - 0.8 Kgm - 5.8 ft/lb), check gasket for wear and replace as required
