Torque specs for TR650
Discussion in 'TR650' started by RuggedExposure, Sep 23, 2013.
  1. RuggedExposure Now with more rugged!
    BFE
    Terra 650
    '08 Meanstreak 1600, '95 DR350
    I posted this over in ADV earlier this year, haven't seen it over here yet. It may prove useful to some, enjoy:
    Useful Information/Specs
    Valve clearance (with engine cold)
    Intake............................................ .................0,009 ÷ 0,011 in (0,23 ÷ 0,28 mm)
    Exhaust........................................... ............. 0,015 ÷ 0,017 in (0,38 ÷ 0,43 mm)
    Spark plug type.............................................. .................."NGK" MAR9A-J-G06
    Spark plug electrode gap............................................... .....0,024 in (± 0,004 in)
    0,6 mm (± 0,1 mm)
    Drive chain dimensions........................................ ...................520KR0 112 links
    lubricating oil................................ CASTROL POWER1 RACING SAE 10W-50
    Oil and oil filter replacement.................................................. ................... 0,44 Imp. Gall. / 0,528 U.S. Gall. / 2.0 l
    Topping up oil between minimum and max. level.................................. 0,055 Imp. Gall. / 0,066 U.S. Gall. / l 0.25
    Torque Specs (Nm):
    Fastening of tank assembly screw on LH side 8,0
    Fastening of mesh oil filter on chassis 10,0
    Fastening of oil pipe clamps 3,0
    Fastening of plug on union for oil drainage from chassis 24,0
    Fastening of oil delivery/return/breather pipes on engine 38,0
    Fastening of rigid pipes on engine cylinder head seat 12,0
    Fastening of engine to chassis on LH side 5,0
    Fastening of oil refuelling cap on chassis 10,0
    Fastening of ECU to support 8,0
    Fastening of ECU support to chassis 8,0
    Fastening of ignition/starter lock 19,0
    Fastening of handlebar clamps 19,0
    Fastening of steering upper plate nut 80,0
    Fastening of handlebar clamp screws 19,0
    Fastening of fork plate side screws 19,0
    Fastening of brake pipe screws to pumps/callipers/ABS ECU 24,0
    Remove the two screws of the bottom yoke on LH side and refit with plate 12,0
    Tightening of bushing for adjustment of swinging arm clearance 6,0
    Fastening of swinging arm pin to chassis 120,0
    Fastening of engine lower screw on chassis 38,0
    Fastening of engine LH screw to chassis 38,0
    Fastening of engine RH screw to chassis with spacer 38,0
    Fastening of engine front clamp nuts 24,0
    Fastening of engine clamp plate - close 56,0
    Retrieve the lower clamp upper screw - reclose 56,0
    Retrieve the lower clamp lower screw - reclose 56,0
    Fastening of clamp on throttle body coupling 0,6
    Fastening of earth cable to engine cylinder RH side 8,0
    Fastening of nut for starter motor cable 6,0
    Fastening of neutral sensor cable to engine RH side 0,8
    Fastening of turn indicator screws 2,0
    Fastening of light support to upper plate 5,0
    Fastening of front fairing support bracket screws to light support 2,0
    Fastening of filter box air temperature sensor 2,0
    Fastening of cover to filter box base 2,0
    Fastening of central front locking to filter box base 2,0
    Fastening of filter drawer to filter box base 1,5
    Fastening of filter drawer to filter box 2,0
    Fastening of top of shock absorber 56,0
    Fastening of bottom of shock absorber 56,0
    Fastening of rear suspension kinematic mechanisms 80,0
    Fastening of airbox to RH seat of chassis 2,0
    Fastening of expansion tank to chassis (LH side) 1,0
    Fastening of airbox to chassis (LH side) 8,0
    Fastening of pinion guard 4,0
    Fastening of rear chassis 28,0
    Fastening of fuel tank to rear chassis 8,0
    Fastening of fuel tank to chassis (RH side) 8,0
    Fastening of gear shift pedal to chassis 13,0
    Fastening of number plate holder to rear chassis 2,0
    Screws for fastening saddle release onto chassis 8,0
    Screws for fastening saddle release onto chassis 3,0
    Fastening of rear mudguard lower clamp to chassis 2,0
    Fastening of ECU to support plate 6,0
    Fastening of ECU support plate to rear mudguard 1,5
    Fastening of sprocket 19,0
    Screw for fastening footrest fixing plate onto support 8,0
    Fastening of rear brake master cylinder 8,0
    Fastening of rear stop switch cover 0,7
    Fastening of stop switch support 2,0
    Fastening of rear brake lever 28,0
    Fastening of side stand 38,0
    Fastening of side stand switch 5,0
    Fastening of silencer to chassis 19,0
    Fastening of silencer and manifold clamps 19,0
    Fastening of front manifold to cylinder head 19,0
    Fastening of Lambda sensor to manifold 45,0
    Fastening of heat-protecting cover onto exhaust manifold 8,0
    Fastening of RH and LH footrest supports to chassis 56,0
    ABS - Fasten rear brake pipe to master cylinder using screw and two washers 10,0
    ABS - Fasten rear brake pipe to master cylinder using screw and two washers 24,0
    Fasten the delivery and return pipes to engine seat 3,0
    Fastening of top of radiator to chassis 8,0
    Fastening of BLOW-BY pipe from filter box to engine ignition cover 2,0
    Fastening of BLOW-BY pipe to filter box 2,0
    Fastening of horn 5,0
    Fastening of voltage regulator plate to engine 5,0
    Fastening of front mudguard / fork guards 5,0
    Fastening of front wheel axle 80,0
    Fastening of screws on fork feet 8,0
    Fastening of front brake calliper 38,0
    Connect and fasten front brake pipe to brake calliper seat 24,0
    Terra-fastening of wire guide plate to LH fork guard 1,5
    Strada-fastening of wire guide plate to mudguard 1,5
    Fastening of front wheel speed sensor 8,0
    Fastening of voltage regulator 8,0
    Nut for rear wheel assembly pin 30,0
    Tighten rear wheel axle to torque 100,0
    Screw for fastening brake hose ring to swinging arm seat 7,0
    Fastening of rear wheel speed sensor 8,0
    Fastening of chain casing 8,0
    Terra-fastening of pushrod to front mudguard tail 1,5
    Fastening of front fairing / front mudguard lower clamp to plate 8,0
    Front fastening of front fairing lower clamp to light support 2,0
    Rear fastening of front fairing lower clamp to light support 2,0
    Fastening of front headlight to support 2,0
    Fastening of voltage regulator guard 5,0
    Fastening of anti-theft cover 2,0
    Fastening of rear brake oil tank 2,0
    Fastening of chain slider to swinging arm 5,0
    Fastening of clutch control assy clamp 5,0
    Fastening of LH switch to handlebar 2,0
    Fastening of front master cylinder to handlebar 5,0
    Fastening of RH switch to handlebar 2,0
    Fastening of throttle control to handlebar 3,0
    Fastening of front brake disc to rim 11,0
    Fastening of rear brake disc to rim 11,0
    Fastening of tone wheel to brake disc 5,0
    Fastening of chain roller 8,0
    Fastening of fuel pump ring nut to tank 6,0
    Fastening of fuel cap ring nut 3,0
    Fastening of reflectors to number plate holder 0,8
    Fastening of turning indicators 2,0
    Fastening of licence plate light to number plate holder seat 3,0
    Fastening of tail light to number plate holder seat 3,0
    Fastening of radiator guards 1,8
    Fastening of sides to chassis 1,8
    Fastening of side connecting cover 1,8
    Fastening of scoops 1,8
    Fastening of tank cover 1,8
    Fastening of heat-protecting covers onto silencers 5,0
    Fastening of front fairing 1,8
    Fastening of luggage rack 19,0
    TE250Guy, Riding Again and Scutler like this.
  2. Riding Again Husqvarna
    Palm Coast, FL.
    2012 TE511
    Sold TriumphTiger800xcx, TR650 Terra
    Thank you for the information. what does it mean when they say: 1,8
    Is it 1.8NM ?
  3. hasenpfeffer Husqvarna
    CO
