Torque Specs on 2007 TE610 Right Side Engine Case?
Discussion in '610/630' started by Caine, Mar 21, 2014.
  1. Caine Husqvarna
    TE610
    I did the primary drive nut fix on my 2007 TE610 and after tightening things up found that I had an oil leak at the gasket. Can anyone verify the proper torque settings for those case bolts? (I have a shop manual on disk around here somewhere but can't find it! :( )
    Thanks!
  2. blueknob Husqvarna
    pa
    2007 te610
    1979 harley davidson superglide
    manual states 6.5ft.lbs, but i would guess you have them tighter than that already.
  3. zoomdude57 Husqvarna
    Seattle
    2009 TE610
    KTM 200XC-W
    That is correct - 9Nm or 6.5ft-lb
  4. Caine Husqvarna
    TE610
    Thanks! They were a little low...looks like tightening them up fixed it...was just too afraid to put the 6.5ft/lb. hammer on them I guess haha. :)
  5. Stroker Ace Husqvarna
    I set mine at 8ft lb. never leaks, never comes loose. Just be careful when torqueing that light....
  6. JonXX Administrator
    Bill's Motorcycles Plus
    360CR 360WR SM610 TC450 TXC250 TC250
    Hondas, Harleys, Yammys & a squid
    I torque them to 3/4 grunt with one hand on my 1/4 drive ratchet
    or
    6-8 impact clicks on my electric 1/4 drive impact bit driver
