Toybike - Yamaha style
Discussion in 'Non-Husqvarna Motorcycles' started by ray_ray, Sep 10, 2014.
  1. ray_ray Mini-Sponsor
    The Philippines
    My friend Bogi (Leyte) said he thinks this bike is an early 70s model ... Pretty unique in a few ways for its day - Shaft drive, single rear shock, oil pump, auto-clutch, no transmission, single-sided swing arm ..
    Big Timmy and Kevin_TE250 like this.
  2. Motosportz CH Sponsor
    PW50 or 80 motor which is also the swingarm.
  3. john01 Husqvarna
    Powhatan VA
    Single sided swing arm! That bad boy is trick :D.
  4. ray_ray Mini-Sponsor
    The Philippines
    Yep and I'll have to update my list above on that SA...
  5. john01 Husqvarna
    Powhatan VA
    Pretty sure it's the PW50 engine as it looks exactly the same as my 5 year old grandsons. Left hand kick starter, shaft drive, and all. The 80 is right hand kick and chain drive.
    Motosportz likes this.
  6. Motosportz CH Sponsor
    I knew it was one of those just did not care enough to check into it :D
  7. john01 Husqvarna
    Powhatan VA
    HA I only had to step into the garage :D. He scares the crap out of me on that thing. It flies with his light little butt on it and that with it governed down :eek:!
  8. 454x Husqvarna
    Dunnigan,Ca.
    2012 CR165 w/36mm lectron.
    I think its a qt 50. The pw guys like the trannys from those because they are geared lower.
