I have a 2010 txc250 and it appears the TPS is not working. I pulled the plug off and there was some corrosion. Cleaned up the best I could and still not working according to the Power Commander. Has anyone had one go bad? I tried to look up the part # but no luck.
Haven't hear of one going bad. Maybe the Powercomander is wrong- maybe its just the set up of the Power commander that's wrong. I dont have one so forgive my ignorance. But I've hard of Power Commander's being set up wrong alot more than TPS failure. Do you have Ibeat to check it? If not, I'd go through the PC set up and doeble check that- then if the problem persists seek out hooking up to Ibeat. To minimize further problems and costs.
