Hello Huskylovers! Is there anyone that can help me with what resistance value the tps should have? And which pin is which? V T G M A on the throttelhouse. My engine runs only with zero throttle. Many thanks from Sweden. Jonas.
Okey! But I got the throttelhouse in my hand and want to see if the tps is working when i twist the throttle. I need 2 values no throttle and full throttle. Cheers.
What i mean is 960 to 970 mvs at no throttle, Dont worry about the full open throttle settings, Just worry about the closed one, its not hat needed as the closed loop. Because you have a 08 model you cant do any i-beat tuning to your ecu.If your looking for better performance go for a powercommander 3 usb or 5 with a autotune they make it a completly different bike to ride.
