Hi there im from Germany and Have a TR 650 Terra, The Abs Modulator/Pump was broken and now im Order a Functionaly Pump in eBay and Put IT in the Bike. Now the Problem: The Abs Symbol is still lighting and Motoscan Show me the fail Code 63CO. This means coding Error. So is IT possible to coding the Abs Modul? Thanks Jan
Hello jpoppi89. Is this the message from BMW fault codes? BMW Fault Code Lookup Error! Invalid code entered. Codes must start with "P" or be a valid hex number. Enter a BMW fault code (P or hex), complete the Captcha, and click "Search" P-Codes will start with a P and are usually generated by generic scanners. Example: P1055 Hex Codes are typically given by more advanced scanners. Example: 180101 or 1B9308 or 30FF. I'm not a IT guy but you could try swapping the electronic components with the the old abs unit. The fault with my old ABS was sticking pump motor brushes. Hopefully someone more knowledgeable will hop in with a simpler solution as access to the ABS is a major undertaking.
