TR650 FRONT SPROCKET NUT/BOLT TORQUE SPEC?
Discussion in 'TR650' started by Husqanick, Mar 2, 2013.
  1. Husqanick Husqvarna
    TR650
    I have a new 15T sprocket - now I need to install... Anybody know the answer to this mystery?
  2. Wyotr650 Husqvarna
    TR 650
    BMW F800gs, Scopra sy 250 r, wr 250f
    According to the service manual, I read 40 NM. 1 NM= 0.7356 ft/#. I obtained service manual at dealer by asking and having a thumb drive for them to download onto at no charge. Hope this helps.
  3. Husqanick Husqvarna
    TR650
    Thanks. This is yet another number that I had not seen before. I've looked mainly on BMW sites to find specs for the 650 motor and the figures vary greatly depending on the year/model - confused further by the f650 twin (800) (one of the dumbest things BMW ever did...).
    In general, 40NM seems low for this application. It seems certain that 40NM will not over torque the bolt...
    Now I have to see about getting a manual from my dealer...
    THANKS again! I really appreciate it.
  4. Leo Fisher Cafe Husky - Contributing Member
    Albuquerque, NM
    TR 650
    Ducati, Honda and Norton
    Nick, I've seen 50Nm for the F650 GS - PJ's sold me the wrong sprocket too! Now I've got to wait for the new one to arrive.
  5. nev.. Terrarist
    Greensborough, Australia
    '13 TR650 Terra
    '14 XT1200ZE
    My dealer loaded a copy of the service manual onto a thumb drive for me as well. The thing I was mainly interested in was the torque specs. Unfortunately, the description of the parts in the torque chart seems to be a poor translation from Italian to English. Some of the descriptions in the manual do not match anything in the rest of the manual. I was particularly interested in the torque for the engine mounts after I installed the bashplate, and almost nothing on the list matches the description of the bolts which mount the engine to the front and rear of the frame.
  6. Husqanick Husqvarna
    TR650
    Mine is the correct sprocket; just put it on. No problems.
    Now I need to find the rear axle torque value... this information should not be a mystery. The USB manual has the procedure for checking and tightening the chain (similar to the F800, S1000 etc) but NO torque values...
  7. nev.. Terrarist
    '13 TR650 Terra
    '14 XT1200ZE
    From the service manual -
    Tighten rear wheel axle to 100Nm
    And yes, the manual lacking what you would think is must-know info is quite quirky. The owners guide is supplied in soft copy on USB (I never received this USB with my bike but I downloaded the manual from the Husqvarna website). The bike came with a hardcopy "quick start guide", which seems to be identical to the owners manual but with 20% of the pages removed. Strangely, stuff which you would think should be on the paper manual, particularly, the running-in procedure / maximum revs during the first 1000km is only in the softcopy version and not the hardcopy, so anyone picking up the bike should ignore the paper manual under the seat and instead locate a computer, and read the soft copy version before riding the bike. It's mad.
  8. Husqanick Husqvarna
    TR650
    Thanks for the Torque spec...
    Same as BMW G650GS. Back to work on the bike...
  9. tweber Husqvarna
    Annual Tour de Go West
    Tr 650 terra
    Zippo
    Was 40nm the right torque? And do you thing I need a puller?
  10. hasenpfeffer Husqvarna
    CO
    Workshop manual torque table - "Fastening of sprocket ... 19,0 Nm"
    It does not specify front sprocket, and I don't see anything about another sprocket, so it is a little unclear. However, the next few specs after this are in the same area as the front sprocket, such as rear brake master cylinder, and foot rest. I'm pretty sure this is referring to the front sprocket.
  11. hasenpfeffer Husqvarna
    CO
    However, found in the engine torque figures section of the workshop manual, it is clearly pictured 40 Nm for the countershaft sprocket bolt. I'd go with that. And I think I might check mine ;)
  12. Nick780 Husqvarna
    83 Suzuki GS400E
    Swap between the 15 and 16 tooth a few times a year. Tighten to 40 Nm each time. Always snug when I get at it, doesn't feel excessive before the wrench clicks.
  13. tweber Husqvarna
    Tr 650 terra
    Zippo
    Thanks guys
  14. MotocycleWriter Husqvarna
    North Alabama
    TR 650, TE 250
    BMW R1150RT, BMW R100GS
    Where are y'all getting your sprockets. I need a 17T for street riding with my new Strada wheels. :-D
  15. DeLewis Husqvarna
    Melbourne, Australia
    Plug "JTF402.17" into the eBay search field. The last number indicates the tooth count for JT sprockets so you can just adjust the last number if you want a different tooth count.
  16. MotocycleWriter Husqvarna
    North Alabama
    TR 650, TE 250
    Yeah, I tried that. But I can't read Serb! Ah, there's one in jolly ol' England. Got my case saver from Down Unda' in no time. Might as well buy it from the Crown.
  17. mag00 Husqvarna
    Tucson
    Terra, Strada
    XR250 R1100RS CH50
  18. MotocycleWriter Husqvarna
    North Alabama
    TR 650, TE 250
  19. Ogre_fl Husqvarna
    Cook Bayou, FL
    Terra 650
    Tiger 1050
    Was Brad not able to get you one?
  20. duibhceK Husqvarna
    Chapel of the Well, Belgium
    TRX850; WR450F; XT660Z Tenere
    Definitely do that. I checked mine a few weeks ago because I was hearing the chain rub against something. Turned out the nut had worked partly loose and there was some side play on the sprocket. A dollop of loctite and done up to 40Nm. That should do it.
