Hi guys, I have a terra 650 with the lowering kit and would want to shift to the original rear suspension link. I'm ok to swap or purchase if one is available. Pls just pm me. Thank you. Miko
Hi Miko, Sorry I don't have what you need but as the title says "TR650 owners in Manila, Philippines" says, I'm just checking in. Butch
Hi Butch, Thanks. No prob. I may have found one but will know by tomorrow. Hope your happy with yours as I am with mine. I dunno if there's a local tr650 group but if there is one and there is a get together pls do let me know. Thanks. Miko
There is a group created in facebook - Husky Club Philippines - HCP A lot of TR 650 owners in PH are there. Come and join. Cheers!
miko, my husky had the lowering kit when i got her, went to grandstar and they just swapped it out with the standard link to bring it back to original height.. no charge.. jodie
Thanks Jodie, I'll ask them about that but when I called they did not have any stocks available. Unless someone is looking for one with a lowering kit. Had I know it would bottom out I would have stuck to the original links. I'll let you know... Aside from that everything is fine. Thanks again pare
The shock and the link that pivots are the ones that limit travel, u can grind the part that touches.
Tr650 rider from manila too. Strada. Had the same problem with the lowered strada. It was rubbing on something under load so i swapped the link out for the original link from granstar. In hindsight it might have been the rubber flap protecting the shock spring from the rear tire spray. Check it out, it may have come loose and maybe touching the rear tire.
Good afternoon, I have a terra and am in Cebu. Where are the other husky owners buying your parts . Any parts. The dealers in Cebu are less then informative. I am looking for tires as I have about 2000 Kms left on mine. Thanks.
