TR650 Screens
Discussion in 'TR650' started by Moff69, May 30, 2014.
  1. Moff69 Husqvarna
    Gordonvale, Cairns, Australia
    TR 650 Strada
    Honda XR600-Sold, wasn't riding it
    Hey guys, l have been asked to post some pics on whatl have done to the stock screen on my Strada to reduce some of the buffeting that l get on a daily ride. So instead of clogging up the Strada top speed post, l throught l would start a new one
  2. Moff69 Husqvarna
    TR 650 Strada
    I have placed a 3mm grommet under the two top bolts for the screen. This has worked to greatly reduce the buffeting that l havebeen getting have testedit out to 160kph with a increase in the "smoothness" of the ride by tilting the top of the screen up a bit, in effect, increasing the angle of the screen. 07-3mmspacer.jpg
    Nordland likes this.
  3. Moff69 Husqvarna
    TR 650 Strada
    When l can get some longer bolts, l will try the 3mmon the bottom with 5mm on the top, hopefully replicating an idea l got of the web, as l still seem to get , greatly reduced, buffeting in traffic. madstadgood.png madstadgood.png 9 madstadbad1.png
  4. Moff69 Husqvarna
    TR 650 Strada
    3 and 5mm grommets, not fitted as l need to get longer bolts for the top. 03-3mmand5mm.jpg 04-3mmand5mmfitted.jpg
    snail_72 and Nordland like this.
  5. Nordland Husqvarna
    North of Germany
    TR 650 Terra
    Thank you for the pictures :thumbsup:
    Moff69 likes this.
  6. Moff69 Husqvarna
    TR 650 Strada
    No problem mate, hope it helped.
  7. Cpan Husqvarna
    New zealand
    Terra 650
    Drz400,Crf230,Ctx200
    Cheers moff69 . I get terrible buffeting with stock screen, removed it after 100km
    Naked terra much quieter but winter riding here in NZ not much fun
    Gonna try your method tomorrow .
    Moff69 likes this.
  8. Moff69 Husqvarna
    TR 650 Strada
    Let us know how you go, l am currently only running the 3mm spacer, and it is so much better.
  9. Hansi Husqvarna
    State of Jefferson
    TR 650
    09 Versys
  10. Jon Knutson Husqvarna
    Mildenhall, United Kingdom
    2013 TR650 Terra ABS
    2007 KTM 450 SX-F (Street Legal)
    The website won't load for me...
  11. Baddrapp Husqvarna
    Yucca Valley
    TR650
    Try the from your phone/I pad button at the top left. It worked for me.
  12. Mel Husqvarna
    Aspley, Queensland, Australia
    Terra 650
    Hi Moff 69
    Appears to be a simple, effective, $friendly solution. Could you please advise where you can purchase
    the 3mm grommets. Thanks
  13. Moff69 Husqvarna
    TR 650 Strada
    I got mine from my local rubber shop, jenkins rubber, but clark rubber should have them or even an auto store, cost about 50cents each.
  14. Moff69 Husqvarna
    TR 650 Strada
    I have just finished fitting up the 3 and 5mm rubbers, will let you all know how it goes on the morrow.
  15. msmith345 Husqvarna
    Shawnee, KS
    '12 WR250, '92 360, '80 390
    '72 Yamaha R5, '17 SV650
    From the pictures those grommets appear to be roughly 3mm and 5mm for each of the outside lips. What is the total height of the grommet? Maybe 9mm and 13mm?
    I ask because, I likely will not be able to get metric grommets locally, so I was going see about grabbing some rubber washers, then stack some regular washers in between to get the desired thickness, still maintaining some of the benefits of the rubber mounting.
    Thanks, it's such a simple and cheap solution that I have to try it.
  16. kiwiape Husqvarna
    650 Terra
    Aprilia DD750
    moff69, the smoothest and quietest is NO SCREEN AT ALL, from there it just buffets or gets noisy. The single biggest things that stop buffeting is a lower screen angle or if you cant do that (as with the OEM screen) try lowering the height. I experimented with about 15 different designs and arrived at this, very little noise over no screen and no buffet. Chest blast is reduce (not hugely) and Cell phone on bars stay dry in the rain.
    http://www.cafehusky.com/threads/windshield.30603/page-8#post-401615[IMG]
  17. Moff69 Husqvarna
    TR 650 Strada
    I have just got back from a 200 klic ride this arvo, at 100kph, and what l have done with the screen works well for me, but l did come from an old XR600 that had nothing.
  18. hasenpfeffer Husqvarna
    CO
    So, you like the 2 different grommet setup better than the single grommet setup?
  19. Moff69 Husqvarna
    TR 650 Strada
    Still a bit un decided, might cut down the 3mm grommet a bit and give it a go, or pack the top out a bit with a couple of washers. I think it is just going to be a bit of playing. I have noticed a lot less buffeting in traffic, but seem to be getting more airflow under the helmet.
  20. JBrown Husqvarna
    Odessa, MO
    I put a madstad screen on my bike a few months ago. The tall one 22". I went out last night and played with different adjustments. When I would push the screen up and out I would get some buffet and a lot of air that felt like it was coming from underneath. I found out that our cool looking side panels might be causing it. I have long legs so I put my toes on the pegs and raised my knees to fill in the curve in the side panels(right under where the TR650 sticker is). This made the wind rush from the bottom hitting my chest and under the helmet instantly stop.
    Moff69 likes this.
