Trail tech computer install
Discussion in 'General (Main)' started by Wadman, Mar 3, 2010.
  1. Wadman Husqvarna
    south carolina
    I got my trail tech vector today and have been installing it. Does anyone know why I need to hook it to the battery when it has a watch type battery in it. I know that if that battery dies it would be a back up. Im not hooking up the temp sensor because I dont want to cut my radiator hose. So that means I will only use one of the wires off the back of the computer.
  2. Wadman Husqvarna
    south carolina
    Never mind I decided to read the instructions and it gave me the answer.
  3. Wetdog Husqvarna
    Tsawwassen, BC
    Cut the rad hose. It's quick and it's not a big job. Knowing water temps in tight twisty stuff is a pretty sweet feature. The main reason I bought one
  4. petem Husqvarna
    Andover, UK
    I'm thinking about maybe getting a Vector myself at some point so any pictures and thoughts on your experiences installing/using it would be very helpful. :thumbsup:
  5. Suamico SD Husqvarna
    NE Wisconsin
    TXC 250
    KTM 350 , Gas Gas Raga 300
    I just installed one on a SV650 with no problems, they do a great job with the instructions. Plus you get the cool looking Red anodized temp sensor thing!
  6. Wadman Husqvarna
    south carolina
    My sv650 had all those features from the factory. The piece for the radiator hose on mine is black plastic so thats why I dont really like trust it. Ive never had my husky overheat unlike my KTM'S .
  7. ray_ray Mini-Sponsor
    The Philippines
    The instructions are pretty good and mine when on easy and believe me, I'm not good at installing things ... My speedo hooked up easy as the magnet for the brake fit the hole exactly on the front disk and my brake cylinder had a mounting for the cable built right into it ... i think I used the default setting of the device in this area...
    Temp gauge was no problem either ... just slice into the water line :) you might have to push some reset buttons on the device, but no problem there...
    I got the top mount for my bike also so when hitting the track for some racing, I remove the 4 bolts from the top of the handlebar bracket and remove the entire device ... After watching the RPM gauge on the trails, I can change gears by sound now ...
    I wish I had an oil temp gauge for my bike ...
  8. ioneater Husqvarna
    NW Texas
    2010 TXC 250
    08 Sprint
    The instructions are pretty thorough. Water temp sensor is no problem. Hardest part is draining/reservicing coolant. Fits like a glove. I had to drill my front brake rotor a tad for the magnet. Wiring is very easy for power, if desired.
    Edit: I'm using Hiway Dirt Bike clamps/guards which incorporate a vapor/vector guard. Probably similar to Trailtech's version. AWESOME guards by the way!
  9. Wadman Husqvarna
    south carolina
    I used the magnet w/o the plastic around it and used marine epoxy to hold it in place. This is what the guys at Trail Tech told me to do.
  10. motosapiens Husqvarna
    kuna, idaho
    I've never overheated a motorcycle except when my 200 spark arrestor was totally clogged up, so I don't really care about the temp sensor. My bike doesn't have a battery so I didn't hook it up to the battery (although you probablyl figured out that the backlighting stays longer, and so forth if you have external power). I also only used the 1 wire, which conveniently plugged right into the existing cable from the stock (useless) computer.
