Trail Tech X2 hack
Discussion in 'General (Main)' started by Spice Weasel, May 16, 2016.
  1. Spice Weasel Husqvarna
    UK
    08 SM610
    Trail Tech are going to hate me for this...
    The main (lower) bulb failed to ignite in my X2. It had hardly had any use, and i found myself needing to replace it. At £57 for another bulb, i said NO, and looked for other options. The whole bulb and glass reflector and lens are one piece on the Trail Tech bulb, the bulb is bonded in with ceramic glue, so you cant just buy a regular HID bulb and fit it into the reflector.
    I found this - http://www.ebay.co.uk/itm/New-1x-4-Inch-Xenon-HID-4x4-Off-Road-Rally-Driving-Work-Flood-Light-Lamp-Shell-/161977915627?hash=item25b6a2d8eb:g:rhcAAOSwDuJWwJrahttp://www.ebay.co.uk/itm/New-1x-4-Inch-Xenon-HID-4x4-Off-Road-Rally-Driving-Work-Flood-Light-Lamp-Shell-/161977915627?hash=item25b6a2d8eb:g:rhcAAOSwDuJWwJra
    and took a gamble that the reflector with lens would fit in the Trail Tech housing.
    Well it did! I had to replace the plastic retaining ring behind with metal tabs to hold it in place.
    Now i can replace the H3 HID bulb for £7 a time when the bulb fails.
    268fords and bigjon like this.
  2. eddychecker Husqvarna
    Sycamore, IL
    2011 TCX250 & 2013 TE300
    2008 KTM 450XCW
    You can also change the top light for an LED MR16 bulb like this one. It has 600+ lumens, brighter than the halogen it replaces.
    DESCRIPTION
    Philips 10 Watt MRX16 LED 4000K 12V 650 Lumen 80 CRI Bipin (GU5.3) Base Black Dimmable Flood Bulb (10MRX16/F35 4000 DIM HO 10/1)
    bigjon and Spice Weasel like this.
  3. Spice Weasel Husqvarna
    UK
    08 SM610
    Thats good to know, thanks. Are they really brighter than a 35w HID?
    I probably done the wrong thing keeping the HID main lamp, i bet theres a better 4" LED one.
    I dont know anything about LED bulbs. That one looks like it has no lens, how does it keep the weather out?
    Any more info, advice on how to replace the top light for an LED one?
    I want to avoid buying replacement parts from Trail Tech now, theyre SO expensive
  4. eddychecker Husqvarna
    Sycamore, IL
    2008 KTM 450XCW
    No, it's not brighter than the HID. It is brighter than the halogen it replaces. I put an LED H3 bulb in mine to replace the lower lamp as well. Here is the link from ebay link.
  5. Spice Weasel Husqvarna
    UK
    08 SM610
    I should have made it clear that my light is the X2 HID http://www.trailtechproducts.co.uk/acatalog/X2_HID_Light.html It is a really good, bright light, works very well and looks pretty good, just replacement parts are very dear. I am interested in the LED replacement 2" light, it seems like the only option than Trail Tech, do you have any pictures of it in place?
  6. Spice Weasel Husqvarna
    UK
    08 SM610
    That bulb isnt suitable, the weather will ruin it. A replacement bulb will have to be a sealed unit.
    The Trail Tech UK website is down now aswell :confused:
  7. eddychecker Husqvarna
    Sycamore, IL
    2008 KTM 450XCW
    Spice Weasel likes this.
  8. Spice Weasel Husqvarna
    UK
    08 SM610
    I forgot about that.
    Its not recommended to be fitted to the HID because they say it stops air cooling the bulbs and shortens their life. Im not worried about that now because the H3 HID bulb is cheap.
    M advice to anyone buying an X2 headlight is to buy the halogen model, then upgrade the bulbs.This is what i should have done, and saved a lot of money.
    I wouldnt have bought the X2 HID in hindsight.
    If the UK site comes back online i will order a rock guard and replace the bulb like you have.
    Thanks for being so helpful eddychecker.
    eddychecker likes this.
  9. Spice Weasel Husqvarna
    UK
    08 SM610
  10. 268fords Husqvarna
    Powell, Wyoming
    08' TE510'
    I removed the projector for my street X2 and fit a 10w led pod flood in there. I had to file the fins a little to fit. The rubber seal fit perfectly. The projector just didn't cut it. I swapped the high beam to a 55w bulb years ago after installing a relay for the headlights.
  11. eddychecker Husqvarna
    Sycamore, IL
    2008 KTM 450XCW
