250-500cc Tranny oil
Discussion in '2 Stroke' started by redbone, Oct 27, 2009.
  1. redbone Husqvarna
    Salisbury, NC
    What brand and weight oil are you using in the tranny of a 250/300 2-stroke?
  2. Clayfan Husqvarna
    Ontario, Canada
    Bel Ray Gear Saver
  3. MOTORHEAD Husqvarna
    Mount Vernon, Indiana
    2014 YAMAHA YZ250
    Castrol Power RS R4 4T Engine Oil 5-40w
  4. Eurofreak Husqvarna
    Western NY
    1986 TE 510, 1982 CR250, 2008 WR250
    70's Triumph , Bultaco , Maico, etc
    Spectro Clutchsaver
  5. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    when I had a little shop back in the 80s, I stocked a lot of Lubridyne products. I had a case of that left over and I'm just down to my last bottle of Lubridyne 80wt, then I'll probably use Bel Ray Gear Saver.
  6. Flyin Husqvarna
    Northern NJ
    WR 300
    Rotella T 15-40
  7. BikeSDP Husqvarna
    Longmont, Colorado
    None @ moment
    990 Adv, Multistrada 1200, 500 EXC
    Nerd alert here: I am using Agip City 4T 10W40. It's actually marketed as a scooter oil. My transmission failed, but it wasn't due to my oil choice.
  8. PC. Husqvarna
    Beaverton, OR
    CR165 & CR144
    KTM500
    Rotella T 15-40 non-synth.
    Run it in all my bikes, smoker or stroker.
  9. razornpc Husqvarna
    iowa
    +1 :thumbsup:
  10. Dirtdame Administrator
    Rock Springs Wy
    17 Beta Xtrainer
    Eh...all you guys talked me into it. I like a good bargain. Rotella will be my next purchase for tranny oil and maybe motor oil.:D
  11. john01 Husqvarna
    Powhatan VA
    +3 on the Rotella 15 - 40 non syn ( the stuff in the white jugs ).
  12. Motosportz CH Sponsor
    Rotella synthetic works fine as well. No clutch slippage. I like Amsoil and use that when i can find it EZ. Spectro Gear Saver has always been my top choice for transmissions that don't shift EZ. Seems like good stuff. On a 2 stoke i feel you can run any good oil. it does not get real hot and you should be changing it a lot anyway because of clutch material contamination.
  13. oneal Husqvarna
    uk
    1999 wr 250 returned home.
    07 TE 450 2005 TE 450 1999 CR 125
    Im runing rock oil lite gear oil and never had a problem
  14. kzoo Husqvarna
    Michigan
    WR 295
    Amsoil 10W-40
  15. Dirtdame Administrator
    Rock Springs Wy
    17 Beta Xtrainer
    I like Rock Oil products and used to carry them in my shop, but I can't find them in the USA anymore.
  16. 2whlrcr Husqvarna
    Dubuque, IA
    Northland Superline 15w-40 non synthetic. I have also used Northland 10w-30, 10w-40 and 20w-50 MXP racing oil. Just depends upon the weather and what I have laying around.
  17. 2whlrcr Husqvarna
    Dubuque, IA
    You should be using Northland.
  18. wulf22 Husqvarna
    Utica, NY
    Another vote for Rotella 15-40 Use it in both 2 and 4 strokes:thumbsup:
  19. oneal Husqvarna
    uk
    If your a retailer im sure you can order direct from rock oil in the uk
