triple torque??
Discussion in '610/630' started by 04asphalt, Mar 21, 2010.
  1. 04asphalt Husqvarna
    SW Michigan
    looked through the service manual and can't find the torque of the four bolts, triple tree on the fork legs:excuseme:
    page and section?
    what is the value? upper or lower bolts first?
  2. tagalong Husqvarna
    Rome, GA
    Front fork legs fastening screw/ M8x1,25
    25 Nm
    2,5 Kgm
    18.4 ft/lb
    On page X.6, first listing on the page. Didn't state a sequence.
  3. 04asphalt Husqvarna
    SW Michigan
    thanks brother:thumbsup:
  4. tagalong Husqvarna
    Rome, GA
    You are welcome.
  5. K7MDL Husqvarna
    Woodinville, WA
    Yep, 18#
    Les at LT Racing rebuilt my front shocks recently and suggested 12# especially for the lower clamps. He also sees signs of overtightening on too many fork tubes including mine. Too tight and you compress the thin tube and cause increased fork slider wear and stiction.
    Another tip he gave was to snug them up by hand, and then tighten each only one time to spec with the torque wrench, not alternating back and forth. He thinks that leads to overtightening as each one loosens the other.
    - Mike
  6. R_Little Husqvarna
    NJ
    That is too tight.
    the forks will bind @ 25nm
    more like 20nm on the bottom bolts and 25nm on the top.
