Trouble Pulling Kick Start Lever Off Shaft
Discussion in 'Vintage/Left Kickers' started by mattmcphail, Aug 4, 2011.
  1. mattmcphail Husqvarna
    Jacksonville, FL
    I'm new to mechanics so with the "barn find" bike I mentioned in my other post I'm using this as a low risk opportunity to take apart / rebuild a motor as a learning experience.
    I've got the engine down to just the bottom end, but I'm having trouble getting the kick starter off the shaft. I tried tapping it out from behnd with a screw driver and hammer but don't want to damage the piece or the shaft. Any tips?
  2. mikedbike2002 Husqvarna
    Montebello,Ca.
    Did you completely remove the pinch bolt that holds it on the shaft? It fits thru a groove & holds it on. If you did then tap a screw driver into the opening in the arm mount to widen it & try tapping it off again.
  3. grouty Auto Lover ...
    South West UK
    78 390WR, 78 390 AMX, 500 Humph
    works 73 CCM 520, another 73 CCM520
    From the pictures in your other post it looks like the kicker is secured with a nut on the end of the shaft.
    With this removed, and it still not shifting, then there is the possibility of the end of the shaft having twisting slightly. Usually due to the nut having come loose at some time.
    I had this issue earlier in the year. Easily solved with the careful use of a two or three legged puller. Make sure you check the splines for straighness !
  4. 1Tuff500XC Husqvarna
    I was just going to say, if what ever the retainer/retension method is, has been removed. Whether it be a clip or bolt, if slightly spreading it doesn't work, a common puller should do the trick. Such as an automotive tie-rod or pulley puller.
  5. mattmcphail Husqvarna
    Jacksonville, FL
    cool. Am I going to need special tools to split the cases, pull bearings etc? Are these Husky / Cagiva specific tools or something I can pick up at an auto parts store or bike shop?
