Trouble with "Sensor map"
Discussion in '610/630' started by Josebdx2002, Jan 2, 2012.
  1. Josebdx2002 Husqvarna
    Barcelona (Spain)
    Hello, my bike run bad. Checked with husqvarna diagnostic machine and say "error in sensor map".
    I looking for this sensor map in the bike and I can't find.
    Where is the sensor map?
    Is in the Throttle body?
    Thanks
  2. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
    If there is an error in the map, I'm pretty sure this is in the ECU, or Electronic Control Unit, and you would need either a re-flash of this unit or a new ECU. The map icontrols fuel and spark at all RPMs. It is square and about 3 inches to a side and under the gas tank with about two dozen wires leading in. It has a connector.
    Perhaps they mean TPS or Throttle Position Sennsor. They should have set yours on that diagnostic machine, assuming they know how. Also could mean Temperature Sensor. Some have failed and need replacement, not much money or trouble to do. Is this a good knowledgable Husqvarna Dealer or did the just start selling them?
  3. Josebdx2002 Husqvarna
    Barcelona (Spain)
    Thanks a lot, a try the options you say.
    Regards.
  4. _luke_ Husqvarna
    Slovenia, Europe
    Could be lambda sensor failure?
  5. Craigl Husqvarna
    NJ
    Could be the air pressure sensor in the M.A.Q.S. unit on the side of the throttle body.
  6. KLOC Husqvarna
    Edmonton, Alberta
  7. Josebdx2002 Husqvarna
    Barcelona (Spain)
    Is the issue I have with my Husky. But I haven't power up, is stock power engine.
    With remove the o2 sensor of the exhaust and put a resistor the problem is ok?
    Or change a new lambda sensor=o2 sensor?
    Thanks guys.
  8. glangston Husqvarna
    2012 BETA 350 RS
    What did the dealer say when he got the message on his software diagnostic machine? They should know what it means.
  9. KLOC Husqvarna
    Edmonton, Alberta
    How is your bike running bad? Doesn't start, runs poorly when cold or when hot, stumbles when hard on the gas ... ?
  10. Josebdx2002 Husqvarna
    Barcelona (Spain)
    The dealer only interested in sales bikes, the chief mechanic every year change, and they haven't experience in Husqvarna.
    Sales Hondas, Mv Augusta, Bmw.
    And for faster resolutions I looking information in this great forum.
    The bike is in warranty, the next week they start to change items.
    The bike run bad like this:
    http://www.advrider.com/forums/showpost.php?p=16836862&postcount=2048
    Thanks.
  11. Josebdx2002 Husqvarna
    Barcelona (Spain)
    Hi, temperature sensor and lambda sensor change, the bike start and run ok. But lights and speedometer not run or when run, run with lower intensity.
    Any idea about this?
    Thanks.
  12. Josebdx2002 Husqvarna
    Barcelona (Spain)
    Lights right now are ok, bad conection in relay:
  13. Josebdx2002 Husqvarna
    Barcelona (Spain)
    Another problem with the engine start, with the diagnostic machine the value of trothle is 107%, i think too much benzin, the optimus value is 100%?
    Problem with the sensor map?
    Thanks a lot
  14. Josebdx2002 Husqvarna
    Barcelona (Spain)
  15. SilverBullet Husqvarna
    Harmaston, TX
    2011 TE630
    I have asked this same question in multiple threads and yet to get a definitive answer. My TE630 was found at 102.4% throttle, after I reset the TPS it increased to 102.7%. Another TE630 I hooked up to iBeat was found at 101.1%
    Per the EFI/Carb forum here on CF, other Huskys have recommended WOT% setting of either 100.1 or 100.4 depending on model. But nothing ever documented for the 610 or 630 that I can find. I asked two dealers and one guro but none knew for sure either. My bike runs perfect so I'm leaving mine where it is at for now.
    Only related info I could find in the manuals was that when and if TPS could not be reset then you would need to adjust throttle body hard stop adjustment screw so it could get back into range. So as long as you can continue to reset and sync TPS and your closed throttle is 0% I wouldn't worry too much.
    _
