Trying to find cam/timing chain for 07 TE610
Discussion in '610/630' started by pbwebguy, Jun 28, 2014.
  1. pbwebguy Husqvarna
    07 TE 610
    Kaw KLX-300, KTM EXC-F 250, Kaw Conc
    I have been calling around the US for a cam chain but there are none in stock. Hopefully someone knows of where I might be able to find one?
    Thanks!
  2. Kyle Tarry Husqvarna
    Portland, OR
    2012 WR 300, 2006 TE 610
    Ducati Monster S2R 800
  3. exvitermini Husqvarna
    kawi
    From the massive amount of searching I've done, it turns out a Kawisaki 02 z600j timing chain uses the same DID part number. I will be able to confirm hopefully in the end of the week when it shows up.
  4. Borgschulze Husqvarna
    2007 TE 610
    2004 Yamaha WR450
    Can't find much on that model... maybe another similar bike has the same cam chain?
  5. exvitermini Husqvarna
    kawi
    Multiple diff kawi's had the same chain.
    I have it in hand, part # 92057-1397.
    I just found another sheet from an even different company stating that those models use the SCR0412 SDH 122 chain.
    I will be tearing into mine and doing the chain and a bunch of seals here in the next couple of weeks. From all outword signs it would appear the chain is correct. It sure looks correct.
