krussell
Strada Adventurer
Tubed tire noob seeks wisdom...
I'm trying to get prepared for tubed tire repair in the field, specifically on my Terra. On my Strada I averaged about 2k mi between punctures, I'm slightly overdue for my next one. Being tubeless, the Strada repair goes something like:
1) pull over
2) find culprit
3) get out tire pump and Nealy kit - http://www.tirerepairkit.com
4) remove culprit
5) insert plug
6) inflate tire
7) put away tire pump and Nealy kit
8) resume ride
It's literally like 10 minutes, I've had 100% success over many bikes over many years. I suspect my lifetime pavement puncture average is about once every 10k, but they definitely come in streaks.
On to the tubed tire repair in the field...
I've changed many bicycle tires, fixed many bicycle flats so I understand the principles. I've got a set of heavy duty tubes to go on the Terra, which I'll do in the garage to get some experience the actual act of the fix. I've got all the tools I think I need, and I've watched some youtube stuff and read some instructions. I'm confident I'll be fine in the garage.
In the field, I'm stuck in one spot. Here's the high level sequence.
1) pull over
2) find culprit
3) lift up bike on jack (oops, no big ol' motorcycle jack in the field)
4) remove wheel, fix puncture, reinflate
5) replace wheel
6) lower bike off jack (oops)
I think there are four options, without the jack, to the get the bike in position so a wheel can be removed:
1) kick it over on it's side
- this helps evaluate crash bar performance, is free, but I'm not sure how well it works. Seems like all the fluids end up in an unusual state, or you lose fuel, etc. - Does this 'just work' and I'm over thinking it?
2) find the perfect tree / rock / large cat / etc to prop the bike up on and keep it stable.
- I think this is an urban legend, and there are definitely places I know I ride that would not have what I need. The idea that I'll stumble upon a puncture right here just isn't realistic...
3) use one of those cool trail stand things: http://www.endurostar.com/
- I think I read in a recent thread that these work well with the TRs. Can anyone confirm? Anyone like these on other bikes? Seems brilliant if it's stable enough.
4) get a center stand.
- Seems like the safest approach. $200 though. Downside is a bit more weight, which does not bother me, not sure if there are other downsides, I've had them on a lot of street oriented bikes and they've worked for me.
One additional requirement for me is I have to be 100% self sustained. I ride mostly alone, and I find myself more and more in places that would result in a very long walk out.
I'm thinking either centerstand, or endurostar trail stand with the other two options as backup. I'd love to hear from folks who have something that has worked well for them.
1) pull over
2) find culprit
4) remove culprit
5) insert plug
6) inflate tire
8) resume ride
1) pull over
2) find culprit
5) replace wheel
