hamiltonuh60
		Just finished up installing my Tubliss system front and back.  I'm glad the box came with extra high pressure tubes.  I accidently snagged one with my tire iron when installing on rear rim.  The front set right in place with no leaks.  The rear had a leak by the high pressure valve and had to let the air out, break the bead, and apply lots of soapy water.  Then it was good to go.  I tried different set ups with the hole location.  On the front tire I have the two holes located on opposite sides, this may become an issue later on.  For the rear, I did what Tubliss recommended and placed the holes about four inches apart.  I think that the roll of spoke tape was the most time consuming task, the whole system went together easier than I thought it would.
Took it out today and did notice a slight weight reduction. Didn't get a chance to play with different pressures. Today I had 14 font and 13 rear. I'm not going to play too much with the suspension settings right now, waiting to get some new Motoz tires and then go from there.
 You must live in a parking lot. I tried to ride across my yard the other day and thought I had a flat, but was actually digging a trench. I rode up to Horn mountain in Sylacauga last week, it was muddy up there also. Mud everywhere, and then add in frozen water in the 2" to 4" range.
 I told my wife dont be surprised if our house slides off the hill like those in California.
