250-500cc Tubliss system
Discussion in '2 Stroke' started by wxc300, Dec 14, 2013.
  1. wxc300 Husqvarna
    I have been using tubliss for over a year and really like the system, I use bridgestone 403 and 404 intermediate tires at 10 psi. I ride eastern conditions with lots of roots and rocks in KY. Some are saying with tubliss use dunlop mx71 front and d739AT rear, harder ties lower pressure. I am thinking of trying it out and they recommend 4 psi. Im thinking at such low pressure will the red tubliss liner wear out because of touching the tire much more with this lower pressure.
  2. 454x Husqvarna
    Dunnigan,Ca.
    2012 CR165 w/36mm lectron.
    The red liner already touches the bead of the tire that's how it works. The bead of the red liner squeezes the bead of the tire and locks it against the rim. You should have no problems people are running the d739at with 0 psi in that set up. I run 7 psi with an MT43.
  3. wxc300 Husqvarna
    I know how the system works. Im talking about the outer diameter of the liner rubing the tire.
  4. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    i run really low pressure like 5ish no problem and i got as many rocks n roots as anybody
  5. 454x Husqvarna
    Dunnigan,Ca.
    The liner rides in the drop center of the rim so I could see the hard terrain tire flexing to the pointof touching the red liner. You should be fine. Give us a ride report whe you can.
    Tim.
  6. firecrotch Husqvarna
    north bend, wa
    2009 wr300
    2007 ktm 950SM
    do you guys have issues with air leaking out if the bike sits a week or two? I got them when they first came out but I had them both almost go flat if they would sit over a week. Filling them up before a ride they would be totally fine during the ride, but it was so diconcerting I switchwd back to regular tubes.
  7. 454x Husqvarna
    Dunnigan,Ca.
    Mine lose a little air but dont go flat. With standard tubes I would take for granted checking the air, now i check air religiously.
  8. sabortooth No Class
    Izard Co. Arkansas
    11uptite167
    The instructions state clearly that the bladder loses air over time. If thats an issue, fill the bladder with nitrogen.
    BadMotoWeazal and 454x like this.
  9. BadMotoWeazal Husqvarna
    Alabama
    I've been using Tubliss since they came out with an 18" rear system.... That's been a while & I have had ZERO problems. I've used many different tires & the best has been the desert tire on the front & rear. The MX-71 front & 739 rear was golden, but the new AT-81 front & rear are the best combo with the Tubliss system I've ever used when racing. And of course I have a trials tire (MT-43) mounted on another rear wheel just because I love a trials tire in the rocks & roots from time to time when trail riding. 6-7 psi in the front & 3-5 psi in the rear.
    454x likes this.
  10. firecrotch Husqvarna
    north bend, wa
    2009 wr300
    2007 ktm 950SM
    huh i missed that. if thats the case i may have to switch back then
  11. wxc300 Husqvarna
    Im going to try the mx71 and d739at the next I change tires out in the spring time and run about 4 psi.
    454x likes this.
  12. BadMotoWeazal Husqvarna
    Alabama
  13. BadMotoWeazal Husqvarna
    Alabama
    I check the pressure before every ride.... But I did that with the tubes too.
