turning off light will it run ok??
Discussion in '4 Stroke' started by andy j, Mar 20, 2010.
  1. andy j Husqvarna
    colchester uk
    Hi guys.. just a quicky
    going racing tomorrow and do not want to have the front headlight on..
    whats best way to turn it off? pulling bulb? still need the actual unit just do not want it turned on.
    i feel real dumb for asking but i read a review where someone stripped off the front light and the bike would not run right? resistor or something like that.
    Would also like to remove the rear at time to time.. its the power up version would this be ok if the front was..
    2010 TE310
    many thanks
    Andy
  2. CARL REHATCHEK Husqvarna
    Tamaqua, Pa
    2010 TE 250
    My thought ... Would it matter if the head or tail light blew while riding ??? Still in the socket but not able to pull power..
    Chow, Carl
  3. hamiltonuh60 Husqvarna
    I removed my front number plate and disconnected the headlight with no issues today.
  4. HUSKYnXJnWI Husqvarna
    Central Wisconsin, USA
    09TE450
    turning off (if you had a off switch) disconnecting, unplugging bulb, running with a bad bulb, et all will not cause a problem.
    I'd take the whole assemble off- and run a number plate off a TXC, if I were racing in places where I didn't need it- just because the assembly can be costly if you cross it up with a tree- been there done that:cheers:
  5. andy j Husqvarna
    colchester uk
    thanks HUSKYnXJnWI thats the answer i wanted..
    yes may get the number plate and use where not required..
    aj
