Twin Leading Shoe Cam Ajustment
Discussion in 'Vintage/Left Kickers' started by 1982 XC 430, Oct 5, 2015.
  1. 1982 XC 430 Husqvarna
    Seattle Wa
    Last Winter I built my 83 250 CR works replica. The one thing I just threw together was the front Brake. On the two rides I have ridden the bike the front proves to be totally worthless. The Steel Drum is badly pitted and will probably need to be replaced. I hope to ride it this weekend and plan to work over what I have. I will check the wear pattern on the shoes and drum and sand them in as necessary. The one thing I'm not sure about is the adjustment of the Cams. I just adjusted them so that they were parallel when I put them together. How else would one do it ?
  2. silverstreakNZ Husqvarna
    Christchurch nz
    82cr500,76gp360,90wr250,81 420AXC
    74 tm400 , 02 gasgas ec 300
    back off/ take off the linkage/adjuster rod . wind the cable adjusters untill the one shoe starts to drag . back it off till it doesnt . then adjust the linkage rod till the other pad does the same .
    then you know both pads are same distance from lining / both getting used .
    i just made that up right then . makes sense to me . no doubt others might have other ways
    aside from truing the drum and arcing the pads etc .
    my cr500 only has a sls front brake . really need to give it some tlc to make it the best it can be
  3. GaryM Husqvarna
    Austin, Tx
    1981 430cr second 430 CR 500cr
    1981 490 Maico
    The twin shoe is really worth having . Once it set up just has a great feel. It progressive and just helps
    make the bike stop.
    If needed there is a shop that puts an insert/ sleeve in the hub itself to restore to better than new.
    RUF likes this.
  4. jimspac Husqvarna
    Connecticut
    86 400WR, 82 Montesa Cota 349
    It also is imperative to have the backing plate sleeved for the cam actuator. Play within that in itself impairs the braking effectiveness
  5. Kartwheel68 Husqvarna
    Newnan, Georgia
    It also helps a lot to have a larger linkage rod between the two cam arms, the stock rod can flex making all your delicate adjustments worthless.
  6. dukkman Husqvarna
    Warwick Queensland Australia
    85/WR 400,86/WR 240,83/430 is mates
    69@71/TS90-76/TS100-72/DKW-78/PE
    And to lengthen the top arm to increase leverage , as below.
    ajcmbrown likes this.
  7. PEZBerq Husqvarna
    Brisbane, Australia
    390AMX, 430XC, 240WR, 2x510TE, FE501
    What brake shoes do people find work the best? I use the EBC from Phil in U.S. Is there a better supply?
  8. 1982 XC 430 Husqvarna
    Seattle Wa
    Think I will end up using a different Hub that has a better Brake Liner in it. I assume that the Hub stayed the same as the single arm brakes of the same era. If not who would I send the Hub to to have a new Liner installed ?
    I have the EBC Grooved Brake Shoes. What other brands are available ? I realize that people have good luck with these Shoes. I however have not. Back in the day I had a 82 Suzuki 175 and I would put a new set of Shoes in and they would work fine until the first water crossing then I would have no brakes till I replaced them. When I restore a Vintage Bike I consider a good deal when the original Shoes are in good enough shape to use again so that I don't have to buy replacements that won't work as well.
    This bike was a very low hour Bike that still had the original rear Tire on it. The Bushings on the Brake Plate are in very good condition. On tear down one of the only parts that had any wear at all wear the front Brake Shoes. They were completely gone just about down to the Backing Plates.
  9. Kartwheel68 Husqvarna
    Newnan, Georgia
    No, the hubs are different. One has a slightly smaller brake drum ID than the other but I cant remember which is which. The backing plates have a lip on the outside that goes on the outside of a raised ridge on the hub, if you machine off the lip on the backing plate you can use either backing plate with either hub, but it is not a direct bolt together.
  10. 1982 XC 430 Husqvarna
    Seattle Wa
    Anybody know what the Steel Liner inside the Brake Hub is made of besides Mild Steel ? I have a Lathe and I could make my own. That is unless its some sort of real hard material.
    The Front Brake deal is no longer the big deal. Seized the Bike up today on the back Straight at Riverdale Washington. I think its a Piston Seize as the Bike acted as if it was running out of Gas and didn't just lock up the rear Tire.
  11. Kartwheel68 Husqvarna
    Newnan, Georgia
    Woody Graves of Woody's Vintage GP replaces liners using engine cylinder liners and turning them down to fit each application.
  12. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    air leak seize by the sound of it...check your manifolds and seals
