Txc 310r 2013 Tps Sensor Voltage And Rollover Sensor
Discussion in '4 Stroke' started by jacekbb, Jul 23, 2021.
  1. jacekbb Husqvarna
    Bossier City
    TE 310
    CR500
    what is the voltage on the tps sensor?
  2. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
    Only TE has tipover sensor I believe. That is what a 2010 manual said. Don’t think that would change as TE is street and TXC and TC are race.. If you can locate a shop that has software for your bike it would help. I think it was a little too expensive for individual bike owners compared to iBeat. You have Keihein Digital Fuel Injection. 2012 models like mine (and earlier) had Mikuni and used iBeat software and a serial cable to tune.
    ETA. You might consider TPS (Throttle Position Sensor) setting to be like the old TDC (Top Dead Center) readings in the old days. It’s a starting point that then regulates both spark and advance as well as the pulse of the Injector
  3. Giack Husky310R Husqvarna
    Piemonte, Italy
    TE310R EVO2-TE 310R MP19-WR300 SB
    Ktm 300 factory 2011
    Husqvarna xlites from 2010 to 2014 never had any tilt sensor. I'm the king of tps setting and I've done a lot of experiments of setting it by using ohms values read with the multimeter with no results...the bike runs best with OEM factory tps voltage spec wich is something between 540 and 600 mV. Mine is set at 590 and with PCV map with all zeros (no alterations) she runned pretty good with acceptable hot start. 1,1 mV makes the bike too fat and will never run good at low revs when the engine is warm. By moving the tps ccw you are shifting your map up in the rpms and while its clear that you are adding more fuel at low revs its unclear if there would be a mismatch at higher rpms. I have made all possible attempts and tests with the tps voltage and I can confidently say that in order to have the bike that runs well in warm engine conditions and that you can easily hot start whenever you want, the tps voltage must be less than 600 mV. For setting a precise tps value and have a map that will optimize the stock map3 with your full PC exhaust I suggest you to buy a Power Commander 5 that will make your 310 perfectly dialed in
  4. glangston Husqvarna
    2012 BETA 350 RS
    Power Commander 5 is a good idea.
