Out In The Middle Of MoaB. 2011 Txc 511. Wont Stay Running Unless Start Button Is Held In. A As Soon As The Button Is Released Engine Dies. Thanks In Advance
What About The Temp Sensor. Coolant Is Good. I Bypassed The Clutch Switch And Disconnected The Starter Wire And Held The Start Button In So Could Get Back To Camp. Runs Just Fine With Button Held In. Is Not Overheating. I Appreciate The help
Did the bypass wire become disconnect, I had mine disconnect bellow the plug behind the number plate. Check the ground wire on the left side of the cylinder. The ground wire connected to the spark plug and the cylinder becomes week and brittle in side the insulated wire.
Everything seems connected. Ground Wire Is Ok. If I Jump The Front Relay The Bike Will Run Normally. Anybody Know Why That Relay Won't Stay Triggered. It Shuts Of As Soon As The Start Button Is Released. Relay Is Good.
What relay, the relay switch that is connected to the clutch, if so I disconnected mj e due to the wire being damaged. All I did was to loop the system.
the relay at the front top of left side of valve cover. i am home now so i have some digging to do. jumped that relay and rode it anyway a couple of times.
i figured it out. it was the main power relay. when it was triggered by the start button but not loaded by the engine trying to start it would pass 12 volts to system but as soon as the higher load came on to run the electronics it would drop to 6 volts and the computer would shut off. guess i am buying an extra relay and putting it in my tool kit. that way it will never happen again. still needs the starter relay though, i burned that up trying to get it back to camp.
