Tyre Pressure
Discussion in 'TR650' started by Jaquesdp, Nov 7, 2013.
  1. Jaquesdp Husqvarna
    TR650
    Hi guys, I didn't get my manual, but what is the recommended tyre pressure for front and rear.
    Metzeler Sahara's
  2. AJM6000 Husqvarna
    Western Australia
    Harley Davidson FLTRX & Ducati 749s
    28psi front, 35psi rear for road/hwy by the manual, which I reckon works really well on the bitumen. Off road I drop 8psi in each front and rear, but that's not a Husky recommendation, just 'seat of the pants feel'.
  3. Coffee CH Owner
    The top part is for the Strada:
  4. Jaquesdp Husqvarna
    TR650
    thanks guys..
  5. FreddoFrog Husqvarna
    Scenic Rim, Queensland, Australia
    NC700SA, TTR250
    Just like to bring this up again, specifically for the Strada, are guys running the recommended pressures? 28 psi seems low in the back, with 31 psi up front.
    I'm currently running 32F 24R, but now I've changed my front tyre to a Pirelli Scorpion Rally, it is definitely a lot more twitchy above 100 kmh (60 mph) and gets badly buffeted around trucks.
  6. AUS_TR650 Husqvarna
    Australia
    2008 KLX250S
    Is this a characteristic of the tyre or the front end of the bike?
  7. FreddoFrog Husqvarna
    NC700SA, TTR250
    A combination of the two I'm guessing. I didn't really notice it when I had the original Tourance on for the first 1000km, Tourance is a radial, Scorpion Rally is bias ply.
  8. Greg Jetnikoff Husqvarna
    Bundaberg Australia
    BMW F80R
    I run 28psi front AND back on the Strada. Helps the aweful turn-in at speed. Also helps absorb a little of the rough square bump performance of the rear shock. Still running the original tyres. SOOOOO wish it had a 17" front wheel. May even forego the abs to try it as I have a spare 17" motard wheel at present with a decent tyre on it.
  9. FreddoFrog Husqvarna
    NC700SA, TTR250
    Thanks Greg, I'll try that next week. I did go to factory settings and it improved a fair bit, the waggle started at about 120, didn't get behind any trucks on my test ride.
  10. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
  11. RidingDonkeys Husqvarna
    Paso Robles, CA
    TR650
    Reviving an old thread here. We've determined the recommended tire pressures by the manual. To me, they seem high.
    By the manual
    Terra
    Front: 28.45psi
    Rear: 35.56psi
    Strada
    Front: 31.29psi
    Rear: 28.45psi
    Now, we've also had a lot of folks complaining about head shake or weave in the front end. Not something I've experienced. It occurred to me last week as I was explaining my tire pressures to a MSF instructor that perhaps the weave might be somewhat contributed to too much pressure up front. So post up what you're running and if you have any headshake or weave.
    I'm running 25 front and rear on my Terra-fied Strada (21/17 spokes), and have absolutely no shake or weave on K60's.
  12. FreddoFrog Husqvarna
    NC700SA, TTR250
    Can I also suggest please note if Terra or Strada.
  13. Beemermcr Husqvarna
    2013 Terra - "Burro"
    2007 BMW 1200 GSA, 2000 DRZ400e
    Terra head shakes starting at 70mph if pressure gets much above 30lbs. Heidenau front and rear. 300lb rider
  14. Riding Again Husqvarna
    Palm Coast, FL.
    2012 TE511
    Sold TriumphTiger800xcx, TR650 Terra
    I run recommended tire pressure for the Terra and only notice the death wobble above 90-100 mph unless there is a lot of head wind. Also if you keep a heavy grip at higher speeds it will wobble harder. I am running the stock Metzler tires. I think the nobbier tires play a difference in the death wobble too. Just remind me of my kx500 with nobbies getting close to 100mph wanted to kill you on the street on a trail with nobbies worked well. Not the same with the Terra because of tires more street oriented get less wobble on street but do not dare going fast on sand they love to wash out the front.
  15. drzcharlie Husqvarna
    I always (on or off road) run 18#'s front and 21#'s rear. No head shake at 80 mph, better ride, better traction on gravel.
  16. Lekolite Husqvarna
    Brevard, NC
    TR 650 Strada
    I haven't experienced any head shake. The only time my front wheel gets squirrelly is because I am getting buffeted by the wind causing my arms to move.
  17. Ogre_fl Husqvarna
    Cook Bayou, FL
    Terra 650
    Tiger 1050
    I have been playing with tire pressures for the past few days trying to alleviate the weave with the 19/17 cast wheel set up.
    Above 75 it starts and so far pressures from the low 20's to mid 30's don't seem to make a difference.
    Oddly my 21/18's with the stock metzlers don't start to weave until over 90, which is really not an issue.
    BTW, would you believe "I was trying to figure out why my bike weaves above 75" was not a vaild enough excuse for this guy of why I was running 25 over. :excuseme:
    Jonny B, Chuffa, nev.. and 2 others like this.
  18. drzcharlie Husqvarna
    Yeah, they don't much care about bike anomalies. What bummer....
