125-200cc uk versions of 2 stroke wre125
Discussion in '2 Stroke' started by richgilb, Mar 9, 2015.
  1. richgilb Husqvarna
    Hull, England
    WR165,
    Ducati SS 1100 Evo , Honda VFR 400
    Bit confused....am I right that the old wre125 from around 2002 is actually a trail bike with inferior forks and small carb and autolube but that the new wre125 from about 2011 is actually a proper roadmregistered race enduro version?
  2. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    Later WRE models as far as I know are still nowhere near the spec as a WR althought look very simular. All WRs are or can be made road legal. Late WR 125s are imported with restictors fitted ie a bit of plastic in the carb so it wont open fully, Perhaps this is what may be confusing you.
  3. gazmcfaza Husqvarna
    uk
    husky wre 125
    , yamaha xt 125
    I have the 05 wre, it's the same as the wr from that year bar several things, yes it has autolube with tank under the seat for oil, the carb is a 28mm dellorto with the oil feed running off the side down to the oil pump by the clutch, they came putting out about 14/15 hp from 1997 onwards, rathr than the 30 hp mark the wr did as they were restricted, more for road use, oh, and the cylinder's are different at the front, the powervalves are either bigger or smaller for broader power rather than the wr's/ cr's more explosive high end, they are 12mm vs 18mm [not sure which one for which model]. The cr and wr has a mikuni 36 or 38mm, or a tmx I believe? Everything else is the same as far as I know, I have a bunch of wr and cr parts on mine. Now husky did some deal with ktm lately, so in 2011 ish they stopped the wre/ sms versions and made premix only bikes, based on the ktm exc 125, it looks like there are no longer any cbt legal 125's as they put out 30 hp standard instead, any questions just ask
  4. richgilb Husqvarna
    Hull, England
    WR165,
    Thanks, guys. So the WRE and the WR were available until the end....so now I know this I could do with learning about the difference between these two WR versions. Anything to help me decide between these two bikes? I think the white frame one is the later lighter bike?
    http://www.ebay.com/itm/Husquvarna-WR-125-Enduro-2009-REG-/271753650078?nma=true&si=J4icJ9eyEgTEjUf%2BFyOS6YAJRbk%3D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
    http://www.gumtree.com/p/husqvarna-motorbikes/husqvarna-wr-125-/1103867448
    I must confess the pipe and large alloy tank also appeal but what are those large red coolant pipes all about?
  5. gazmcfaza Husqvarna
    uk
    husky wre 125
    , yamaha xt 125
    the first listing has ended, unless you bought it? I would go for the second bike, 1800 is a good price still. Coolant pipes, if they're any other colour apart from black they're probably after market ones, samco and chinese guys have them on ebay for 50 to 100 ish. Second guy has also put about warming up before riding so assuming he knows what happens if you start and ride off straight away on one of these :D If it's got a standard tank btw , range out of mine is maybe 65/70 miles before I hit reserve, that's 8 or 9 litres so could expect about that out the wr
  6. richgilb Husqvarna
    Hull, England
    WR165,
    Why the second bike?
  7. richgilb Husqvarna
    Hull, England
    WR165,
    Viewing the eBay one on Thursday....
  8. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    If it was my money I would of bought the first one, second one would of clocked a load of road miles methinks.
  9. Geraint Powell Husqvarna
    Wre 125
    whats your intentions regarding the bike you're trying to get????
    i've got an 03 wre which i use for green laning/trail riding and ticks all the boxes, and on a personel level i like the autolube, but if they go wrong:eek::eek:
    and there's no "in, out shake it all about, you do the okey cokey nonsense on garage forecourts
  10. richgilb Husqvarna
    Hull, England
    WR165,
    Brisk trail riding, some hare and hounds and a 165 kit is what I want to do.....brother in law had an early wre and it was not fast enough
  11. R-J van Hulst Husqvarna
    Cambodia
    Honda CB 400 Vtec 3
    Having a wr and a sms the engines are quite different
    looks are the same but internals not
    some SMS features compared to WR
    the SMS is a 2011 and the WR is a 2002
    the frame is a world of difference (the SMS is a better one as the WR and the WR is already very good compared with other bikes)
    gear box is different (and especially from 3rd gear and up) for "tame" road riding OK for wheelying through town and hooligan riding get some serious sprocket changes.
    I am spoiled so my WR is a 165 with a lectron and FMF fatty exhaust.
    the SMS will get the same treatment.
    ignitions different in timing and curve.
    I am getting a CR one with a light coil for the small electronics load and a the few lights
    more important, see the bike as a hobby when spending all the money on it instead of a project that have to make money
    for sure the smiles it will generate it's worth the money and having the perfect bike for you the way you want is great but in the end you will not that far of with the pending as if you would buy a much newer old bike (but not ideally perfect set up for you)
    Robert-Jan
