Upper shock bearing
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by Freaky, Dec 3, 2013.
  1. Freaky Husqvarna
    Kidderminster Worcestershire UK
    2010 TE250 x-lite Race ECU/Injector
    I've got play in the upper shock bearing on my 2010 TE250, not taken it off before, what's in there guys? Bearing, bush, rose joint?? Any after market replacements or is it genuine only?
    Cheers.
  2. Phaeton Husqvarna
    Bend, Oregon
    2007 wr 250
    2011 GASGAS EC 300 2007 KTM 200 XC
    I have the same issue. Waiting for someone with the knowledge to chime in.
  3. duggoey Husqvarna
    NSW, Australia
    2010 TE 310
    KTM 690, Yamaha WR200, FGS650(800cc)
    I put some lithium waterproof grease in there and have kept riding. I think it's basically a bush/collar, not sure of the price there but here in "Aust-oh-so-you-have-a-motorcycle-you-must-be-a-millionaire-ralia" it was going to cost me something above $200 for it..
    Freaky likes this.
  4. kx3089 Husqvarna
    western pa
    wr250
    I've got a spherical bearing in my 08 nwr250
  5. oneal Husqvarna
    uk
    1999 wr 250 returned home.
    07 TE 450 2005 TE 450 1999 CR 125
    im sure that maybe some one like pivot works or all balls do kits, or maybe if you have a local bearing house and you are confident that you can remove the the bearing yourself take it and see if you can get it matched up.
  6. Freaky Husqvarna
    Thanks guys, rang a Husky dealer and, as you say, it's a spherical bearing and will cost me £58 including seals, bit expensive for what it is. A bit more digging and the size is 12mm inside diameter, 26mm outside diameter and 16mm width and has a bearing code of GEBJ12S. I've found them on ebay in china for $8, may order one and give it a go. All balls etc don't list these bearings so seems no other option than over priced genuine.
  7. oneal Husqvarna
    uk
