valve adjustment
Discussion in 'General (Main)' started by moose3006, Sep 8, 2010.
  1. moose3006 Husqvarna
    pelham
    i recently bought an 07 sm510. the bike has had an oil change every 1000 miles, the bike has 5000 miles on it now but never a valve adjustment.
    im pretty mechanically inclined so im going to do it myself. what i dont know are the measurments for the exhaust and intake valves. anyone help me out?
    also does anyone know where i can get a manual for this thing?
    any other tips on maintenance is greatly appreciated
    thanks
  2. AndrewS Husqvarna
    Niagara Region, Ontario, Canada
    2015 FE350s 2013 TE310R
    2009 TE250 (sold)
    You can get a workshop manual here: http://www.husqvarnaoutlet.com/repair_manuals
    As for the valve specs, mine are listed on a label under the seat.
    You'll be able to find yours on a similar label, or if not, in the workshop manual I linked to.
    BTW, are you in Pelham Ontario?
  3. moose3006 Husqvarna
    pelham
    no pelham new hampshire, thanks for the link though
  4. Coffee CH Owner
  5. nocontrol Husqvarna
    Fullerton, CA
    if you are mechanically inclined it shouldn't be an issue. super easy to check/adjust the valves on these bikes, not quite as easy as ktm's or screw type adjusters, but you dont have to pull the cams if you need to change a shim.
  6. moose3006 Husqvarna
    pelham
    yes ive seen that video coffee. you make it look really easy. thanks guys
  7. ghte Husqvarna
    Bright, Victoria Australia
    Our Husky's stay in spec longer than KTM's -promise
  8. MChammer Husqvarna
    North Annville, PA
    This may be a dumb question, but here goes...
    I bought my 2008 TE250 new and the sticker under the seat says...
    Intake .10 - .15 mm
    Exhaust .15 - .20 mm
    I had the 300 kit put on in 2009 and for the first time am going to check the valves....should I keep these same specs now, or does the 310 have different:excuseme:
  9. Coffee CH Owner
    Same specs for all the newer 2 cams. 250/310/450/510...
    Not sure about the new ultralight engine however, and I know the 610 is a different beast all together.
  10. MChammer Husqvarna
    North Annville, PA
    Thanks Coffee...this information combined with your handy-dandy video ought to make this routine maintenance a snap:thumbsup:
  11. Coffee CH Owner
    :cheers:
    I just wish everything in life was as easy as adjusting/checking the valves on an Husqvarna...
  12. racemx904 Husqvarna
    owenton, ky
    2014 Beta 350RR & 1986 430XC
    can you get these shims at an auto place? what size are they?
  13. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    Get the shim kit from Motosportz.
  14. Riksha Husqvarna
    So Cal
    Once after paying the dealer to check & adjust my te450 valves someone told me to just pull the cover and wiggle the rockers, if there is play not to worry about it.
    Was that an accurate/decent suggestion?
  15. Coffee CH Owner
    No I don't think that is a decent suggestion. All it takes is a few minutes and a feeler gauge to check them.
  16. Fast1 Husqvarna
    Minneapolis, MN
    No kidding.. 8000 miles on my TE510 and the valve lash is still in spec and has never required adjustment.
  17. ray_ray Mini-Sponsor
    The Philippines
    Honda 450 shims work also ...but not the 250 ones ...
