250-500cc Vape ignition systems
Discussion in '2 Stroke' started by jpettit, Feb 5, 2021.
  1. jpettit Husqvarna
    cincinnasty
    2001 WR 360
    08 690 SMC, 99 VFR, 98 380 MXC,
    Does anyone have experience with these ignition systems?
    https://www.vape.eu/
    I was thinking about trying one of these for my 360, but they don't have 01-02 listed on their website. cross referenced the part numbers and all the important parts for the 01 share the same numbers with the 99 which is listed here.
    https://www.vape.eu/en/husqvarna-wr-360-kokusan-japan-base-plate-80-mm
    would appreciate input from electrical gurus and anyone who has experience with this brand.
  2. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    I know nothing about Vape
    but the 360 ignition is 93-02 all the same part number
    so if it fits a 99 it fits an 01
  3. jpettit Husqvarna
    cincinnasty
    2001 WR 360
    roger that.
    thanks.
  4. husky jim Husqvarna
    USA
    14 WR300, 87 430wr, 86 430ae, Tr650
    would appreciate input from electrical gurus and anyone who has experience with this brand.[/quote]
    They used to be known as Powerdynamo, Penton Products, and MZB
    I've got 2 Vape ignition systems on both my 1987 430's.
    They are a Quality unit, easy to install, and work Great!
    100 watt 12V DC out put on for lighting, retards timing for easy starting and no kick back.
    I buy from them directly it's cheaper and only took a week to receive.
    https://www.vape.eu/ktm-and-husqvarna
    jpettit and 2premo like this.
  5. jpettit Husqvarna
    cincinnasty
    2001 WR 360
    thanks for that, jim.
    i guess i'm just nervous as to whether the ignition they have for a 99' will work on my 01'.
  6. 2premo Husqvarna
    Northern NV
    like I said, they are the same, I did this some time back
    so in Huskyland the part number can change with a VERY minor revision, like color or adding a hole for a later accessory
    BUT if the part number is the same, it is the SAME, so here if you still doubt is the PROOF
    8000 75334 is used from 1993 to 2002 on ALL 360 models, the 92 is different
    5A48B5B3-CA97-44B7-9E1F-779F42A24054.jpeg E026DF99-8B7E-42C8-9D64-207A81A46E62.jpeg
  7. jpettit Husqvarna
    cincinnasty
    2001 WR 360
    I dig it. i actually cross-referenced the part numbers before i started this discussion. you are most certainly correct. I trust you to not talk out of your ass.
    i guess the next logical step is to buy it and try it.
    flyingbob and 2premo like this.
