125-200cc Vapor digital gauge for my husky
Discussion in '2 Stroke' started by RPMKICK, May 25, 2014.
  1. RPMKICK Husqvarna
    Husqvarna SMS 125 '02
    Are there any Vapor gauges that will show RPM, Speed, Temperature and km distance? And are there any that will fit my Husqvarna SMS125 '02? Is it plug and play?
  2. Kyle Tarry Husqvarna
    Portland, OR
    2012 WR 300, 2006 TE 610
    Ducati Monster S2R 800
  3. darnold87 Husqvarna
    Salem, Oregon
    2007 SM610 Adventure
    I'm wanting to do the same thing on my 2002 WR125. Trailtech's website only shows the Vapor back to 2005 bikes. And Amazon.com shows it as "not compatible" on my 2002.
    However, I called Trailtech today and the tech guy said that they will work and the model to use is 752-700 (that's the black one). Still, I'm a little nervous to pull the trigger and also curious if anyone else is running one on a pre-2005 125 or similar?
  4. Kyle Tarry Husqvarna
    Portland, OR
    There is nothing special that happened in 2005 that would make it not work. The units are not "plug and play" per se, you need to connect them to the battery, run the coolant temp wire and sensor yourself, run the RPM wire, and sometimes you need to run the speedo wire. It's all really easy stuff.
  5. darnold87 Husqvarna
    Salem, Oregon
    Thanks for that info... I figured as much, as read up on that in the installation instructions online. My WR does not have a battery but the Vapor appears to not require a 12volt battery to operate... Still trying to confirm that.
  6. Kyle Tarry Husqvarna
    Portland, OR
    The Vapor will run off the internal battery, or it will run off the bike's power, AC or DC, over a very wide voltage range. This info should all be on the spec sheet.
  7. darnold87 Husqvarna
    Salem, Oregon
    UPDATE:
    I've installed the Vapor (#752-700) on my '02 WR125. Works great! I haven't hooked it up to the WR's power yet, as some of the bike's wiring was modified from a previous owner and I'm trying to make sure I don't fry the Vapor by hooking up something worng. If you run the Vapor off it's own battery, the screen's backlight turns off after a short delay and the 2 LED light (indicator lights for max RPM & Temp I believe) don't funtion on the unit (according to Trail Tech). The digital RPM indicator also maxes out due to high reving 2-stroke. But as it is, I'm very happy with it. Any suggestions on how to tap into the bike's electrical for a power source would be great! (This is my first 2-stroke / battery-less bike, so I'm still learning).
    PS - sorry to hack the thread, just trying to help contribute information...
    http://www.trailtech.net/752-700
  8. MotoMarc36 Husqvarna
    wisconsin
    2012 CR144, 04 TC450, 04 TC250, CR50
    Many. Too many.
    High-revving twostroke? All modern fourstrokes rev higher. What is it "maxing out" at?!
  9. darnold87 Husqvarna
    Salem, Oregon
    The gauge maxes at 12K. It appears to hit the max pretty easy. Maybe I need to change a setting in the vapor to read rpm / tach signals differently? Still learning the Vapor and the WR... :)
